exw tin dorean ekdosi tou virtual dj 7.0 alla exw problhma otan paw stin sound effect kai pataw sto filter bgeni ena parathiro error poy grafi (error opening xml plugin file) koitaksa pws exei anafer8i ksana alla den exei lh8ei to problhma, parakalo boh8eisteme giati to xriazome to exw psaksi poly to problhma ayto kai den to exw lhsi akoma. mhpws gnorizei kaneis ti prepei na kano? eyxaristo
geposted Wed 24 Aug 11 @ 9:23 am
tha s pw t pisteuw... o mporei na einai kai lathos..
oloi exoume auto t provlima.. auto simbainei gt t filter iparxei sto skin s epanw kai boris na t xrisimopoiiseis apo ekei... apla dn borei na t aniksei t vdj san ksexwristo effect
geposted Wed 24 Aug 11 @ 4:37 pm
Dokimase na kaneis install to Directx9 kai ta Windows Runtime Libraries apo auto to link
http://www.virtualdj.com/homepage/TexZK/blogs/4265/Windows_libraries_for_plugins.html
analoga me toleitourgiko pou exeis prosekse poio arxeio tha katevaseis toso apo to DirectX oso kai apo ta links pou tha deis sto parapanw link sxetika me ta Libraries.
geposted Wed 24 Aug 11 @ 7:36 pm
egkatestisa to Directx9 kai ta Windows Runtime Libraries apo to link pou mou edoses djdad alla den allakse kati
malon 8a simbeni auto pou leei o Achileas7. to eixa proseksi kai sto vdj 6 prin balo to vdj 7, htan poly kalo effect
kata ti gnomimou alla den litourgi sto vdj 7.
h 8ela naksera afou den litourgi sto vdj 7 giati to ebalan sto arxeio egkatastasis... eyxaristo paidia
geposted Thu 25 Aug 11 @ 8:58 am
Kanwntas egkatastasi to software, den peirazei ta plugins sto antistoixo folder. Akoma ki an kaneis uninstall, auta menoun ekei. Ara mporei to plugin na min yparxei sto installation file, alla n asynexizei na to vrikei.
En pasei periptwsi des poio einai to kako plugin kai vgalto me delete apla mesa apo to folder MyDocuments\Virtualdj\Plugins\Soundeffecrts
geposted Thu 25 Aug 11 @ 5:25 pm
ego pali nomizo oti kapoio plugin tou leipei h exei problima kapoio boihthitiko arxeio xml
Tha lysei mallon to problima me to na adeiasei ton fakelo me ta plugins kai na kanei egkatastasi ksana to programma oste na perasei oal ta arxeia.
H entelos uninstal ola kai ksana.
geposted Thu 25 Aug 11 @ 7:24 pm
Πάντως έτσι για την ιστορία το "FILTER" που υπάρχει στο skin του VirtualDj είναι ΤΕΛΕΙΩΣ διαφορετικό πράγμα απο το effect Filter που υπάρχει στα effects του VDJ. Είναι δύο διαφορετικά πράγματα και δύο διαφορετικά effect. Το μόνο τους κοινό σημείο είναι το όνομα τους.
geposted Fri 26 Aug 11 @ 5:19 am
to arxeio plugin sto folder (MyDocuments\Virtualdj\Plugins\Soundeffecrts) den eiparxei djdad .
prospa8isa na kano remove to software kai na to ksana egkatastiso, tou ekana repair kai to egkatestisa kai meso
network alla den alakse tipota apopsis. mhpos xriazetai na egkatastiko kati akoma exw ta vista stis teleytaies
enhmeroshs .
enhmeroshs .
geposted Fri 26 Aug 11 @ 6:52 am
Esvises olon to fakelo plugins opos sou eipa prin ksanakaneis egkatastasi ?
H olokliro ton fakelo : Documents/virtualdj metonomase ton h metefere ton kapou allou gia backup kai ksanakane egkatastasi.
geposted Fri 26 Aug 11 @ 8:24 am
("H olokliro ton fakelo : Documents/virtualdj metonomase ton h metefere ton kapou allou gia backup kai ksanakane egkatastasi.")
ayto ekana kai mou egkatestise ta eidia akribos, den eixe kane pros8eto arxeio.
to arxeio plugin se ti epaiktasi prepei na einai?
geposted Sat 27 Aug 11 @ 6:11 am
telika sto problhma ayto den bre8eike akoma lysei..........
geposted Mon 29 Aug 11 @ 6:09 am
