Can anyone help?
My USB sockets have broken and need to run the sound out of the laptop jack socket, but when i do this i get a horrible noise but only when i have VDJ open, its fine in itunes! any ideas?
geposted Sat 27 Aug 11 @ 3:08 am
If it only occurs in VirtualDJ, then you may have performance issues with your computer or incorrect configuration in VirtualDJ, please see:
http://www.virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
Otherwise, you have ground loop issues and will need to purchase a ground loop isolator.
geposted Sun 28 Aug 11 @ 8:04 am
