Forum: Old versions
Topic: Importing Garage Band
Is there a way to import Garage band samples and loops into VDJ?
If so how do you do it?
geposted Wed 31 Aug 11 @ 11:05 am
Got it figured out sorry for the post before playing around with it and goggling it.
So if you guys want to import you must convert the .caf files to .mp3, and then place them into your sample file then load from there.
I used a program called switch to do the converting it's free software.
http://www.nch.com.au/switch/
After installing import the .caf files then hit the convert button then it should download an extra plug-in needed to convert the .caf file but it does work.
Hope this helps others.
On a mac from garageband go to share export disk then select mp3 destination quality and its converted to mp3
must try
