Hi there.
A long time ago, I am thinking of something that will help most of us.
Yesterday, while I was editing a song on Sound Forge, I have notice that I can rename a mark region.
Please check the following photo
I have load the song "it's raining men" from Geri Halliwell. So, the first mark is in the beginning of the vocals (humidity is rising).
The second mark is on the refren. And the last mark is on the last refren.
On Virtual DJ, I think that it would be a great idea, if you could right click on the waveform and "rename" the que number (for example 2) with a small note that you wish to type.
Do you think that it's easy to add this feature?
geposted Thu 15 Sep 11 @ 10:45 am
You CAN rename cue-points already... Right click on the on cue-point marker on the PROGRESS waveform (the on deck waveform) and hit rename...
geposted Thu 15 Sep 11 @ 12:13 pm
Πλάκα κάνεις!
You must be kidding. That's why I love this program.
It surprises me with these features!
geposted Fri 16 Sep 11 @ 10:45 am
Some skins will even show the name you've given the said cue point ;-)
Huey
Huey
geposted Fri 16 Sep 11 @ 11:05 am
Hi,
Does anyone know the code to allow a skin to show the cue name?
Cheers
Cheers
geposted Thu 29 Sep 11 @ 4:32 am
<textzone chan="1" rightclick="edit_cuename" rightclickvalue="1">
<size width="57" height="12"/>
<pos x="16" y="464"/>
<text font="Arial" size="12" color="yellow" weight="bold" scroll="yes"align="right" format="%Pnamecue1"/>
</textzone>
</textzone>
geposted Thu 29 Sep 11 @ 4:18 pm
Are these cue points and names remembered?
i.e. if you set a bunch of cue points and name them, then go and load another track, will those cues come back when you load the first track again?
geposted Fri 14 Oct 11 @ 10:31 am
of course. Cue names are saved in the database xml file
geposted Fri 14 Oct 11 @ 1:38 pm
Thanks Ludek.
I'll try that.
I'll try that.
geposted Thu 27 Oct 11 @ 5:42 am
I've been using this feature a lot, renaming each cue and writing myself little notes on each so I can remember what I was planning to do at each cue. Now I've switched to a MAC, and I cannot right-click on each cue. Does anyone know how to rename cues using a MAC?
geposted Sun 29 Apr 12 @ 11:15 am
You can always use your keyboard:
action="cue_name" <---This will work on the current cue-point (the cue-point that's currently selected)
You can also use specific commands but this requires more buttons to be mapped:
action="cue_name 1" <---This will work on the first cue-point (cue-point 1)
action="cue_name 2" <---This will work on the second cue-point (cue-point 2)
action="cue_name 3" <---This will work on the third cue-point (cue-point 3)
action="cue_name 4" <---This will work on the forth cue-point (cue-point 4)
In all cases, a small window will pop-up asking you for the cue's name.
geposted Mon 30 Apr 12 @ 2:11 am
Your question has been answered in the other post you made and in the support ticket you raised, but for anyone else right click on a single button mouse under OS X is two fingers on touchpad then click.
geposted Mon 30 Apr 12 @ 6:21 am
