It was about time :)
Version 3 is almost ready ..
- New Colors for background and elements
- New design for the knobs (EQ, FX paramtrs etc)
- 4 Hot Cue points
- Added Cue Points Info (Name, Times, Beats)
- Deck Indicator flashes when song reaches the end
- New Vinyl_mode indicator
- Larger KeyLock button near Pitch
- Added FX Sliders names
- Supports both 1-2-3-4 and 3-1-2-4 mixer orders (with rightclick on the MIXER button)
- Limiter Indicator
- Premium Member indicator
- Record Infos display
- Minor bugs in xml fixes
Hopefully in 2-3 days
Anything else you want to see ?
- 4 Hot Cue points
- Limiter Indicator
geposted Sun 06 Jan 13 @ 12:18 am
- since you added 4 hot cue buttons, how about 4 sampler buttons
- I know you are running out of space but any way you can make those spinners bigger?
- How about swappable panels for 4 button/3 button transport controls as many controllers do not have separate pause and play buttons.
geposted Sun 06 Jan 13 @ 4:43 am
Some controllers are mapped to control 4+4(same) samples, others 4+4(different), others 3+3, others 5 or 6 +. So it would be pointless to have sampler buttons on each deck side.
What i did was to add a MORE button to the deck sampler to open a Sampler panel on the bottom of the screen, so that you can always see which sample is selected, which one is playing etc
Definitely NO !!! hehe.. Spinners are useless to me if they dont offer any infos. I have them there so that the skin reminds the default one
So what will happen if your controller has 1 or 2 buttons for those actions ? The Skin will still give you the current status. Have also in mind that controllers have all kind of control buttons and LED conditions, so supporting them all would be pointless.
I added a 3rd FX slider and a MORE button to hide/show the SoundEffects Page if selected
geposted Sun 06 Jan 13 @ 6:15 pm
djdad wrote :
...What i did was to add a MORE button to the deck sampler to open a Sampler panel on the bottom of the screen, so that you can always see which sample is selected, which one is playing etc
+1
geposted Mon 07 Jan 13 @ 1:20 pm
Hi Bob,
Would love the ability to display other info along with the title, for example year, comment etc.
What I do at the moment is modify the XML myself to change KEY to YEAR and add comment to the name of the song per the example below.
Keith
Keith
geposted Mon 07 Jan 13 @ 2:18 pm
I really like the new Outfit ;o)
CBG-Edit Buttons (if missing so far..)
Greets
Music234
Greets
Music234
geposted Mon 07 Jan 13 @ 4:09 pm
Toggling video output (only) doesn't work for me when clicking 2 or 4 from the skin itself (with Mac).
(i.e using deck 2 as the main player while displaying the video on deck 4)
I have this mapped on my NS6. But it would be better if it would work straight from the skin too (mouse-click/no controller).
This has been my STEADY skin for more than a year now... I definitely love it!
Cheers
geposted Tue 08 Jan 13 @ 8:42 pm
It should work, but you need to see the VIDEO CROSSFADER
If you see the AUDIO CROSSFADER then those buttons assign the audio (and the video if no deck is assigned in the Video Crossfader panel)
geposted Tue 08 Jan 13 @ 9:03 pm
Mine shows AUDIO CROSSFADER (in Video Panel mode)... How can I change that to VIDEO CROSSFADER?
Is there a toggle-switch for this one?
Thanks
Thanks
geposted Wed 09 Jan 13 @ 1:37 pm
You just click on the text of the crossfader. It toggles the audio/video crossfader, just like the default skin ;)
geposted Wed 09 Jan 13 @ 3:42 pm
That easy!!!
Thanks, djdad!
Thanks, djdad!
geposted Wed 09 Jan 13 @ 7:59 pm
kradcliffe wrote :
Hi Bob,
I believe Key is more important than any other additional info, for those who mix in harmonic and Karaoke djs.
I added an i button. Click will provide some additional info (Comment, Year, Album , Genre) and Rightclick will open the File Info window of the song.
Will also satisfy the ones that dont need to show to customers what song they play ;)
Those are easily accessible if you Rightclick on the BPM button and Open the BPM Editor. They dont provide any useful info while you mix, but if u need them they are there :)
geposted Thu 10 Jan 13 @ 3:45 am
Excellent. Thank you!
Keith
geposted Thu 10 Jan 13 @ 3:59 am
And a minor addition since lot of users ask in support how can they change the Master Deck in order the Sync button to work...
Master/Slave buttons instead of text indicators. Hopefully its more clear now for them :)
geposted Thu 10 Jan 13 @ 4:01 am
Thanks ;o)
geposted Thu 10 Jan 13 @ 5:41 am
Default 4 Decks SWAP HD Version 3
Download : http://www.virtualdj.com/addons/13812/VirtualDJ_7_(4_Decks_Swap_HD).html
Resolutions : 1600x900 1920x1080 1920x1200
Changelog
- 4 Hot Cue points
- Added FX Sliders names (more sliders with MORE button)
- Limiter Indicator
- Additional Infos View on each deck
- New Master/Slave buttons
- New Sampler Info Panel (MORE button)
- Custom design icons
Smaller resolutions will come shortly.
Enjoy !!!
Changelog
- 4 Hot Cue points
- Limiter Indicator
Enjoy !!!
geposted Mon 14 Jan 13 @ 6:36 am
There is a problem : I can't load another sample, only the 12 proposed. How to load another mp3 file?
geposted Mon 14 Jan 13 @ 7:56 am
I dont think it has to with the skin though.
To load samples, you need to view the SAMPLER page and click on the Options button next to each slot
geposted Mon 14 Jan 13 @ 8:00 am
DJDAD, just noticed your title change, Congrats!
geposted Mon 14 Jan 13 @ 1:03 pm
Very good Job Dj Dad ;)
geposted Tue 15 Jan 13 @ 9:14 am
