hi
here is the ticket I added, and the response. that is outrageous. basically trying to upsell me. the software doesnt work with a supposedly supported piece of hardware without soem major tweaks to my mac that I am sure will have knock on negative effects. anyone had similar or care to commetn?
Date: Mon 31 Oct 11 @ 9:45 pm
Message: virtual dj le does not install on my macbook pro. xml file problem. i have followed all of the advice on the forums, and i still cant get it too install.
also on my imac (both runnign the same version of lion btw),although it will install, it it won;t find my itunes playlists. i have seen advice about chaning my itunes xml file name, but i dont think thsi would be a good idea, and isnt something i think I should have to do.
i have to say that this makes the dj2go essentially pointless. i am very disappointed as I though this product would be good. i have downloaded the free version through the mac store, and although it works, you can\'t cue a track on it. please advise as I feel very disappointed about this.
Message: Hi,
VirtualDj LE that comes with the DJ2Go is a very limited version. Just VirtualDJ pro Full would work with this controller and give you all support you need. The solution is given, and is the way it would work, iTunes don't mind to be compatible with any other software but iTunes, so they change the names or the program as they want. This don't allow to follow full support without doing some fixes as you are instructed to do so.... sorry
Cheap hardware would be never good. THe best deal now should be a Numark Mixtrack Pro at least or a Hercules RMX or 4MX or a VMS4 or a Pioneer Ergo or a Denon MC-6000.
Kind Regards,
VirtualDJ support Team
Message: Hi,
Kind Regards,
geposted Mon 07 Nov 11 @ 11:40 am
I have one and use it all the time with VDj Pro w/DjIo ,Dj2go lite is something fast and quick to get the feel of Dj. Player 1 & 2 if you get the Full You will be very satisfy with that DJ2Go with that Mac.
geposted Mon 07 Nov 11 @ 3:56 pm
it doesn't install on my macbook. it does on my imac, but to see itunes playlists you have to rename itunes, which I am sure is going to create problems elsewhere. badly made software. i would appreciate a proper answer from the makers, and a decent solution.
geposted Tue 08 Nov 11 @ 3:35 am
Im sorry try this.
http://www.apple.com/support/contact/
geposted Tue 08 Nov 11 @ 9:12 am
or the software could be made to work in the first place. apple will redirect you back to the software manufacturers.
thats not very helpful.
geposted Wed 09 Nov 11 @ 3:42 am
OK, what kind of Macbook do you use?
Also it would be for interest, what OSX you have installed.
VDJ only read the iTunes playlist.
Since iTunes has changed their way, it isn't longer that simple.
I can only advise you to read the following informations from here:
http://www.virtualdj.com/wiki/Controller%20Configuration%20And%20Troubleshooting.html
http://www.virtualdj.com/wiki/Playlist%20Itunes%20not%20showed.html
geposted Wed 09 Nov 11 @ 4:09 am
thanks for the wiki. its the same changing itunes whcih i am not keen on
macbook pro (2010 model) and lion.
keeps saying a skin not there.
geposted Wed 09 Nov 11 @ 7:03 am
thanks, that is exactly the process i have followed already. cheers for trying. not sure if you work for them or not, but its a sad state of affairs.
geposted Wed 09 Nov 11 @ 11:36 am
the installation failed.
the installer encountered an error that caused the installation to fail. contact the software manufacturer for asisitance.
geposted Fri 11 Nov 11 @ 3:54 am
well will haev t sell it on ebay then, as noone from VDJ can be bothered to respond or help. poor software, terrible customer care. avoid.
geposted Mon 14 Nov 11 @ 3:38 am
I bought one and I cant use it because I did not get the serial code with it...it's a brand new one from amazon...what am I to do now?
geposted Wed 13 Feb 13 @ 7:11 am
Contact the store where you purchased it from and ask them to send you the CD (If it was missing) and/or provide you with a replacement.
Please see http://www.virtualdj.com/forums/151663/General_Discussion/Lost_Serials_-_VirtualDJ_LE_or_any_other_version.html
If it came with another DJ software product instead of VirtualDJ LE, then you will need to purchase the full VirtualDJ Professional if you wish to use it with VirtualDJ: http://www.virtualdj.com/buy/index.html
For further advice, please contact support: http://www.virtualdj.com/contact/index.html
geposted Wed 13 Feb 13 @ 7:28 am
