Forum: Old versions
Topic: Pioneer DDJ ERGO mapper
Is it available to Pro Full users?
geposted Mon 07 Nov 11 @ 8:01 pm
It is already fully supported in the latest version - 7.0.5b.
I cant find the Pioneer DDJ-ERGO-V under mappers tab with 7.0.5b build 371 wich is the same available at my download center.
Is it mapped with another name?
Please redownload. There is a new build online. (b380 - as i remember)
Greets, Heiko
Thanks, its native supported at 7.0.5b (b380).
As I said --> It is already fully supported in the latest version - 7.0.5b.
:) ... glad you found it
thumbs up!
even tho i have a question, i had another guys mapper, and a support dude had enough patience that he helped me configued the sound and other basic settings, i wonder now, if i download this one, and i choose the ERGO mappers, what will happen? i think he played abit with the decks since he was asking me if i had sounds from all kind of sorts.
Maybe some buttons will change its behavior if you try another mapper.
The mapper is not related to the sound setup. The sound will not be affected.
Bom dia Speed. Comprei um ddj ergo que veio com o traktor le. Eu tenho o virtual dj pro e gostaria de saber onde baixo o mapper dele para o virtual
abraço
Please use English in this forum.
If you have VirtualDJ PRO then register your serial number.
The latest version of VirtualDJ PRO has full native support for the DDJ-ERGO. There is nothing that requires a download.
Utilize Inglês neste fórum.
Se você tiver VirtualDJ PRO em seguida, registrar o número de série.
A última versão do VirtualDJ PRO tem suporte nativo completo para o DDJ-ERGO. Não há nada que requer um download.
el virtual 8 falla con mapping ergo que hacer
