Hi there i just recently bought
Numark Mixtrack Dj Software Controller
and when i plug it into my laptop it tells me that it will only run for 10 minutes then turn off
can anyone suggest any ideas on how to make it run for longer please
Thank you
Thank you
geposted Sat 19 Nov 11 @ 4:42 pm
Hello ,
That's because you use VirtualDj Home Free ,
VirtualDj Home Free allows you full Pro features to be tried for 10 minutes at a time.
You can restart the software as many times as you like to gain a further 10 minutes trial.
If you have VirtualDJ LE or Console Edition, you should be entitled to a discount in most cases.
Please enter your serial number in the box provided in the UPGRADE TO VIRTUALDJ PRO FULL section of the purchase page to check whether you are entitled and how much discount you will receive.
You can purchase the full version of VirtualDJ : http://www.virtualdj.com/buy/index.html
geposted Sat 19 Nov 11 @ 4:48 pm
ok thank you Dj Sinclair for the help i will give it a go
geposted Sat 19 Nov 11 @ 5:02 pm
or you can install the virtual dj LE version that was supplied with the controler... that is if it didnt come with traktor
geposted Sun 20 Nov 11 @ 3:04 pm
