Topic: Pioneer DDJ-S1
johansPRO InfinityMember since 2005
Looking to buy a new controller, and my wallet goes in the direction of the Pioneer DDJ-S1 (good sound quality)
I want 2 Mics, minimum 1 external source that can work independtly from my PC and 2 decks.
As the DDJ-S1 has only two decks, can I switch decks via Mapping to use deck 1 as 3 & 2 as 4 in VDJ ?
I only need occasionally the possibility to swap between decks
If that works I might go for it.
thanks
geposted Fri 16 Dec 11 @ 5:50 am
geposted Fri 16 Dec 11 @ 2:03 pm
Thanks, I'll download the mapper and see if I can test it in the store where I purchase my DJ stuff
geposted Fri 16 Dec 11 @ 3:18 pm
cstollPRO InfinityMember since 2004
That mapper is for the T1 ... the S1 is natively supported already. No mapper necessary.
geposted Fri 16 Dec 11 @ 3:50 pm
Just one more question.
OK native supported by VDJ but as the DDJ-S1 is designed to work with Itch, do I need to install Itch before it will work with VDJ?
I don't own the unit yet, but I want to be sure that it should work with only ASIO4all driver + VDJ installed.
Don't want to have Itch on my PC.
Somebody can clear this up for me?
geposted Thu 19 Jan 12 @ 3:27 pm
just plug it in, should work. might have to change the input/output sound setup.
geposted Thu 19 Jan 12 @ 3:31 pm
Thanks for the answer
geposted Thu 19 Jan 12 @ 3:50 pm
I bought the DDJ-s1 and it doesnt work with my mac...how did you get this to work?
geposted Thu 14 Jun 12 @ 3:15 am
Haui70PRO InfinitySenior staffMember since 2008
Please try this :-)
Quote :
For Mac OSX - check the device name of the unit in the Audio/MIDI Setup utility.
You will most likely need to rename the MIDI name of the device to 'DDJ-S1 MIDI'
First, make sure that you are viewing MIDI devices, not audio. Click on the Window menu and choose Show MIDI Window.
Click on the appropriate MIDI device in the list. Then click on Show Info.
Click on the Device Name: box and type in the correct name: DDJ-S1 MIDI
Click APPLY.
geposted Thu 14 Jun 12 @ 8:00 am
Hi...i have OS X 10.8.2 and i'm new in mac my questions is how i can rename the DDJ - S1?
i not got option in the menu that said rename
geposted Thu 10 Jan 13 @ 1:04 pm
Applications-->Utilites-->Audio Midi Setup.
From the top menu, choose to View the MIDI page. Double click on the icon of the Pioneer DDJ S1 and rename it as DDJ-S1 MIDI
geposted Thu 10 Jan 13 @ 1:56 pm
У меня есть маппер!
geposted Mon 21 Apr 14 @ 6:09 pm
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
geposted Mon 21 Apr 14 @ 6:31 pm
can any one help me to configure or map virtual dj to pioneer ddj-s1 ?
geposted Sun 03 May 15 @ 4:13 pm
It's already natively supported.
geposted Sun 03 May 15 @ 5:27 pm
