Forum: Old versions
Topic: Mixtrack - HELP
Hey,
I recently bought Numark Mixtrack, included Virtual DJ LE. As it figured out, and as I new it has only one port for USB.
The problem is:
I want the master side in my headphones, but I can't get into it. I guest it should have it feature, if it doesn't please let me know, and if it has please let me know how to make it, thanks.
I don't have Sound Card, if it needs Sound Card to work or anything like that please let me know it too, thanks once again.
Dupree Love, aka Head.
geposted Fri 30 Dec 11 @ 1:49 pm
geposted Fri 30 Dec 11 @ 5:29 pm
Will it work with M-Audio Fast Track Pro? Cause I'm going to buy one.
It it work can you tell me how to work with it long story short?
Thanks.
geposted Sat 31 Dec 11 @ 2:46 am
It's a 4-in, 4-out ASIO card, so yes it should be suitable.
The configuration for use with a MIDI controller such as MixTrack should be:
Inputs: None
Outputs: Headphones
Sound card: ASIO -> Choose the Fast Track Pro in the list.
geposted Sat 31 Dec 11 @ 10:45 am
OK, thanks a lot.
I will upgrade it to Pro version.
geposted Sat 31 Dec 11 @ 11:45 am
