entaksei ekana re-analyze ta ragoudia pou mou to ekane kai tora ok..!!
efxristw!!!
efxristw!!!
geposted Sat 16 Feb 13 @ 7:32 am
alli mia erotii..giati se merika tragoudia den mou emfanizei titlo k tragoudisti?? enw ston fakelo ta exw kanonika???
geposted Sun 17 Feb 13 @ 8:39 am
To VirtualDJ diavazei eite to filename eite ta ID3Tags. H epilogi ginetai apo to Config-->kartela Browser. Sta deskia yparxei epilogi iD3 Artist/Tile.
An den exeis enimerwmena tags kalo tha itan eite na ta enumerwseis me kapoio programma opws to Tag&Rename eite na epilekseis na min diavazei ta Tags.
Prosekse omws, giati kathe fora pou allazeis auti tin rythmisi to VirtualDJ ksanadiavazei kai enimerwnei ola ta pedia, epomenws mporei na xaseis kapoia idi enimerwmena pedia orismenwn tragoudiwn.
Oso ki an ta Tags einai mpelas, thewrw oti prepei na katseis na asxolitheis kai na ta enimerwseis. Kalws i kakws ta Tags xrisimopoiountai apo ola ta programmata, isws poly perissotero akoma kai apo ta filenames. (vlepe iTunes)
geposted Sun 17 Feb 13 @ 8:46 am
katevasa to tag & rename piga se ka8e kommati ki evala title kai artist alla pali ta idia...giati?? :(
geposted Sun 17 Feb 13 @ 9:58 am
To File Infos ti sou deixnei gia auto to tragoudi (deksi click) ?
Einai to filename plires , stin morfi Artist - title.mp3 ?
Ta tags pou enimerwses fainontai sto File Infos ?
Milame gia mp3 ? i gia allou typoy arxeia ?
geposted Sun 17 Feb 13 @ 1:17 pm
Αφού ενημερώσεις τα Tags πρέπει να κάνεις re-read τις πληροφορίες.
Δεξί κλικ στο φάκελο που έχει τα τραγούδια -> Rescan Tags
geposted Sun 17 Feb 13 @ 1:39 pm
Allagi thematos...
Epsaxna kati sxetika me ena trofimo sto google simera kai epesa pano se auto.
Mathete ta PANTA (ta PANTA omos) gyro apo tin "Π____" (5 grammata)
Einai apisteutos o tropos pou to analyei to thema o poihtis !, tha mporouse na exei grapsei biblio.
http://pournari.blogspot.gr/2011/11/blog-post_9930.html
Babis .. Kara LOL !!!
geposted Sun 17 Feb 13 @ 3:23 pm
to eftiaksaa paidia....piga se ka8e arxeio pou eixe to provlima kai ekana deksi klik file info kai to eftiaxna....efxaristw paidiaa...afto tora einai kapoio arxeio me ta tag's pou to sozeis kapws????
geposted Sun 17 Feb 13 @ 4:50 pm
ola sozontai stin database.
Ta tag diabazontai tin proti fora pou h database blepei ena kainourgio arxeio kai grafontai ekei - den ta ksnadiabazei automata xoris logo allios to browsing tha htan poly argo.
An kaneis edit ta tag eksoterika prepei na 'peis' to vdj na ta ksanadiabasei.
Mporeis na to kaneis mazika (batch) oxi ena ena.
Telos yparxei kai h alli lysi na diabasei tous titlous apo ta filename, giati h zoh einai poly mikri na tin pername diorthonontas id3 tags.
geposted Sun 17 Feb 13 @ 5:17 pm
hmm...kaalava efxaritsw poli apopsis!! Kalo vradi k kali evdomada se olous!
geposted Sun 17 Feb 13 @ 5:36 pm
apopsis wrote :
Allagi thematos...
Με άκουσε όλο το γραφείο... Έχω 10 λεπτά που γελάω συνεχόμενα!!! LOOOOOOOOOOOOOOOOOOOOL!!!!
geposted Mon 18 Feb 13 @ 12:31 am
apopsis wrote :
Allagi thematos...
ΑΥΤΗ ΕΙΝΑΙ ΔΙΑΤΡΙΒΗ!!!!
geposted Mon 18 Feb 13 @ 3:36 am
Όταν ο Θεός δημιούργησε τα έθνη, έδωσε στο κάθε έθνος από δύο αρετές.
Έτσι, έκανε του Αμερικανούς τακτικούς και νομοταγείς, τους Γερμανούς αποφασιστικούς και μελετηρούς, τους Ιάπωνες εργατικούς και υπομονετικούς, και ούτω καθεξής.
Για τους Έλληνες είπε, θα είναι έξυπνοι, τίμιοι και θα δουλεύουν στο δημόσιο.
Όταν τελείωσε τη δημιουργία του κόσμου, τον πλησίασε ο αρχάγγελος Γαβριήλ και του είπε:
-Κύριε, έδωσες σε όλα τα έθνη από δύο αρετές, αλλά στους Έλληνες έδωσες τρεις. Αυτό θα τους κάνει πολύ ισχυρούς και θα διαταράξει τις ισορροπίες πάνω στη γη.
-Έχεις δίκιο Γαβρίλε, είπε ο Κύριος. Στάθηκα απρόσεκτος και αυτή η απροσεξία μου θα κάνει τους Έλληνες να κυριαρχήσουν σε όλο τον κόσμο. Κάτι πρέπει να κάνω αλλά δεν μπορώ να ανακαλέσω τις αρετές που τους έδωσα, κι άρχισε ο Θεός να ψάχνει να βρει μια λύση.
-Το βρήκα! Θα παραμείνουν οι τρεις αρετές, αλλά κάθε Έλληνας θα μπορεί να κάνει χρήση μόνο των δύο.
Κι έτσι έγινε:
Αν ένας Έλληνας είναι τίμιος και δουλεύει στο Δημόσιο, δεν είναι έξυπνος.
Αν είναι έξυπνος και δουλεύει στο Δημόσιο, δεν είναι τίμιος.
Αν είναι έξυπνος και τίμιος, δεν δουλεύει στο δημόσιο.
Κι έτσι έγινε:
geposted Mon 18 Feb 13 @ 9:19 am
djdad wrote :
Κι έτσι έγινε:
Κι έτσι έγινε:
Poso dikio exeis...
geposted Mon 18 Feb 13 @ 2:03 pm
λολ
geposted Mon 18 Feb 13 @ 2:18 pm
Chill out.. συνεχιζεται
Όταν ο σύμβουλος ρώτησε ποιο είναι το πρόβλημά τους, η γυναίκα άρχισε να εξιστορεί με πάθος, ένταση και θλίψη όλα τα προβλήματα που είχαν σε αυτά τα 20 χρόνια.
Όλα όμως! Ανέλυσε τα πάντα. Ότι ο σύζυγος δεν την προσέχει, είναι αδιάφορος, ψυχρός, ότι αυτή νιώθει μοναξιά, αποξενωμένη, δεν υπάρχει αγάπη πλέον στη σχέση και όλες τις ανάγκες που μένουν ανεκπλήρωτες από έναν κενό γάμο.
Αφού ο σύμβουλος την άφησε για αρκετή ώρα να μιλάει, κάποια στιγμή σηκώθηκε πάνω, της ζήτησε να σταθεί όρθια και μετά την αγκάλιασε και την φίλησε παθιασμένα!
Ο άντρας παρακολουθούσε με προσοχή χωρίς να αντιδράσει. Μετά από λίγο, η γυναίκα σταμάτησε και κάθισε ξανά στην καρέκλα της μισοζαλισμένη.
Ο σύμβουλος γύρισε στον άντρα και του είπε: Αυτό χρειάζεται η γυναίκα σου. Μπορείς να το κάνεις αυτό τουλάχιστον 3 φορές τη βδομάδα;
Ο άντρας το σκέφτηκε για λίγο και είπε: Κοίτα, μπορώ να στη φέρνω Δευτέρα και Τετάρτη, αλλά την Παρασκευή δεν μπορώ, έχω μπάλα...
geposted Mon 18 Feb 13 @ 6:45 pm
κρυαδες.....
οι γυναικες ΠΑΝΤΑ εχουν παραπονα μονο και μονο για να εχουν κατι να γκρινιαζουν
αμα δε τις προσεχεις, εχουν παραπονο οτι τις εχεις γραμενες ή δε τη θες ή εχεις γκομενα
αμα τις προσεχεις, εχουν παραπονο οτι την πιεζεις ή εισαι ζηλιαρης ή εισαι ανασφαλης ή δε την αφησεις ελευθερη ή τη πνιγεις!
πω πω τι μου θυμησες βραδυατικα και φουντωσα, αμα κατσω και γραψω αυτα που εχω ακουσει και με εχουν κατηγορισει, θα γραψω βιβλιο ολοκληρο!
παω να ακουσω ambient για να ηρεμησω...
geposted Mon 18 Feb 13 @ 7:28 pm
na rotisw kati..an 8elw na antigrasw ta tragoudia m se enan skliro eksoteriko alla mazi me ta que mou prepei na ton antigrafi mesa apo to vdj???
geposted Tue 19 Feb 13 @ 12:54 am
geposted Tue 19 Feb 13 @ 7:59 pm
καλησπερες..τι κανετε παιδακια? μολις εβαλα το crossdj στο ipad και πραγματικα χαζεψα...δε το περιμενα με καμμια δυναμη... οσοι εχετε τσεκαρετε το..
geposted Wed 20 Feb 13 @ 3:09 pm
