aledjo wrote :
poly kalo kai xrisimo programa gia ta matia mas paidia. to dokimasa kai einai ksekourasto
http://stereopsis.com/flux/
to douleuo... Dyo 23ares othones exo otan kano chat, den ginetai xoris na einai xamilomenos o fotismos.
Btw, milontas gia chat... den exeis katolou ypomoni Aledjo etsi ?...
Xtypiseses to koudouni simera alla den perimenes na se aniksoun.....
geposted Thu 02 Feb 12 @ 7:18 pm
imoun biastikos giati ithela na agoraso to vdj gia ena filo kai rotiso pos ginetai update sto mac alla telika to brika.
geposted Fri 03 Feb 12 @ 3:36 am
Pes tou min ksexase na kanei registrater to serial number tou.
Kai na kratisei kai to sale ref number.
geposted Fri 03 Feb 12 @ 4:35 am
aporia:
giati to vdj pro kanei 239.97 + fpa = 295.16 euro
eno to cue kanei 239euro mazi me fpa?
http://www.djshop.gr/displayITM2.asp?ITMID=14455&LANG=GR
de tha eprepe na timi tou online na einai pio ftina?
geposted Fri 03 Feb 12 @ 2:49 pm
Αλέξη μιλάς για δύο "διαφορετικά" προϊόντα. Όσο κι αν το CUE είναι το VDJ rebranded από τη Numark, αυτή καθορίζει την δική της τιμολογιακή (και όχι μόνο) πολιτική. Γι αυτό και τα updates του CUE αργούνε λίγο...
geposted Fri 03 Feb 12 @ 7:01 pm
Kalispera...
Exw mia aporia polu kairo twra... Sto scratching oi miktes pou xrisimopoioun einai kanonikoi?? dld o crossfader einai ''full'' i exei kamia eidiki leitourgia???
geposted Sat 04 Feb 12 @ 10:46 am
To crossfader prepei na exei "cut" curve (kampili). KAi malista oso pio apotoma kai grigora kobei toso to kalytero.
geposted Sat 04 Feb 12 @ 10:59 am
ok :D... gt ok megali epafi me t scratch dn exw alla dokimazodas me kanoniko fader lew... now what???
Thanx!!!
Thanx!!!
geposted Sat 04 Feb 12 @ 11:25 am
allo ena poly xrisimo programataki
http://www.clicktoapp.com/
geposted Sat 04 Feb 12 @ 1:15 pm
aledjo dn kserw an xrisimopieis pontiki (egw pantos oxi) alla iparxoun pontikia p to kanoun auto m ena koubi kateuthian.:):) to exei enas filos m.. vevaia kanei 50 euro kai einai kathara gia gaming
geposted Sat 04 Feb 12 @ 6:44 pm
Ένα ΠΟΛΥ ΚΑΛΥΤΕΡΟ πρόγραμμα για τέτοιες δουλειές (και όχι μόνο) είναι το AutoHotKey http://www.autohotkey.com/
Βασικά το χρησιμοποιώ σε όλους μου τους υπολογιστές για διάφορες εργασίες.
Ένα πράγμα που μου αρέσει είναι οτι μπορείς να ορίσεις ένα Hotkey ανάλογα με το ποια εφαρμογή είναι στο προσκήνιο. Έτσι, για παράδειγμα έχω φτιάξει macros για τα πλήκτρα F ανάλογα με το ποια εφαρμογή είναι ενεργή να κάνουν διαφορετικά πράγματα.
Θέλει λίγο ψάξιμο, αλλά είναι τρομερά δυνατό εργαλείο, και είναι και δωρεάν!!! Επίσης υποστηρίζει και ΟΛΑ τα "ειδικά" πλήκτρα διάφορων πληκτρολογίων και ποντικιών (έτσι το ανακάλυψα).
geposted Sun 05 Feb 12 @ 5:48 am
re paidia na sas rwtisw kati... exw kapoia tragoudia opou lene diaforetiko bitrate apo auto p leei to vdj.. egw poio na empisteutw to vdj i to anagrafomeno.. kserw pws kati me ipsilo bitrate dn einai aparetita kai kalitero apo ena allo me xamilotero, alla edw dn milame gia tetoia katastasi.
geposted Sun 05 Feb 12 @ 9:13 am
Γενικά υπάρχει "τεράστιο" θέμα με τα αρχεία VBR. Σχεδόν κανένα πρόγραμμα δεν δείχνει το σωστό Bitrate. Το ίδιο ισχύει και με το VDJ. Δεν διαβάζει "σωστά" το bitrate των αρχείων VBR. Για αρχεία CBR δείχνει τη σωστή τιμή.
Τώρα αν θες να ξέρεις το πραγματικό bitrate ενός αρχείου VBR θα σου πρότεινα να το παίξεις με το Winamp. Θα βλέπεις σε πραγματικό χρόνο το χρησιμοποιούμενο bitrate και θα μπορείς να κάνεις μια εκτίμηση. Διαφορετικά για να πάρεις το ακριβές bitrate θα πρέπει να διαιρέσεις το μέγεθος του αρχείου σε bytes με την διάρκεια του σε δευτερόλεπτα και να διαιρέσεις το αποτέλεσμα με το 125.
Ενδεικτικά:
Αρχείο μεγέθους 4.939.822 bytes διάρκειας 3:25
3 Χ 60 + 25 = 205 sec
Και το αποτέλεσμα είναι 4.939.822/205= 24.096,692 bytes/sec
Και επειδή 1Kilobit/sec = 125bytes/sec έχουμε
24.096,692 / 125 = 192,77Kbps
Η διαφορά των 192 με τα 192,77 προκύπτει λόγω του header του αρχείου και του id3 tag αν υπάρχει.
Για να το υπολογίσεις σε μέγεθος ακολουθείς την ανάστροφη πορεία:
0,77kbps * 125 = 96,25 bytes/sec
96,25 bytes/sec * 205 sec =19.732 bytes ή
19.732 bytes/1024 = 19.27KBytes.
Ενδεικτικά:
geposted Sun 05 Feb 12 @ 10:09 am
Auta p egrapses ta gnwrizw apla ithela na mathw an iparxei allos tropos:)
tous orous CBR kai VBR dn tous eixa ksanakousei tha to psaksw perissotero:)
edit:
ok meta apo ena grigoro psaksimo eida ti einai to cbr kai to vbr:) alla gia poio logo ena tragoudi na einai ftiagmeno/ixografimeno se vbr??
edit:
geposted Sun 05 Feb 12 @ 10:39 am
CBR = Constant Bit Rate = Σταθερός ρυθμός δειγματοληψίας.
VBR = Variable Bit Rate = Μεταβλητός ρυθμός δειγματοληψίας.
Ο σταθερός ρυθμός δειγματοληψίας χρησιμοποιεί τον ίδιο αριθμό δεδομένων για κάθε δευτερόλεπτο. Επομένως όταν κωδικοποιούμε με 192kbps κάθε δευτερόλεπτο θα καταλαμβάνει χώρο 192kbits (ή αλλιώς 24.000 bytes)
Ο μεταβλητός ρυθμός δειγματοληψίας δεν χρησιμοποιεί τον ίδιο αριθμό δεδομένων για κάθε δευτερόλεπτο. Ανάλογα με την πληροφορία του ήχου την στιγμή που αποθηκεύει μπορεί να χρησιμοποιήσει περισσότερα ή λιγότερα δεδομένα. Έτσι, ένα δευτερόλεπτο μπορεί να κωδικοποιηθεί με 96kbits και ένα άλλο με 256kbits. Ο αλγόριθμος συμπίεσης/κωδικοποίησης προσπαθεί να κρατήσει ένα σταθερό μέσο όρο για όλη την διαδικασία, αλλά σπάνια το επιτυγχάνει. Έτσι παρότι μπορεί να κωδικοποιούμε με 192kbps VBR στο τέλος ο μέσος όρος μπορεί να είναι 256Kbps VBR ή μπορεί και να είναι 160Kbps VBR (και φυσικά και οποιαδήποτε τιμή ενδιάμεσα).
Στον χώρο του Video κυρίως για να λυθεί το παραπάνω πρόβλημα υπάρχει ο αλγόριθμος των 2 περασμάτων. Δηλαδή ο αλγόριθμος την μία φορά διαβάζει και αναλύει το αρχείο που θέλει να κωδικοποιήσει (ώστε να ξέρει πότε και που πρέπει να ανεβάσει ή να μειώσει το bitrate) και στη συνέχεια κάνει το δεύτερο πέρασμα όπου στην ουσία γίνεται και η κωδικοποίηση. Με αυτό τον τρόπο επιτυγχάνεται αποτέλεσμα πολύ πιο κοντινό στον επιθυμητό μέσο όρο. Στον ήχο όμως σπάνια χρησιμοποιείται αλγόριθμος δύο περασμάτων.
Edit:
Το θεωρητικό πλεονέκτημα του VBR είναι οτι μπορεί να φτιάξει (θεωρητικά πάντα) καλύτερα αρχεία με μικρότερο όγκο δεδομένων απ' οτι το CBR.
Για παράδειγμα 2 δευτερόλεπτα "ησυχία" για να κωδικοποιηθούν με CBR χρειάζονται 46,8ΚB. Τα ίδια δευτερόλεπτα σε VBR θα κωδικοποιηθούν με λιγότερο απο 0,5ΚΒ.
Επίσης (πάλι θεωρητικά) ο αλγόριθμος VBR μπορεί να καταναλώσει πολύ περισσότερο όγκο για να αποθηκεύσει την πληροφορία ενος συγκεκριμένου δευτερολέπτου όπου π.χ. μπορεί να υπάρχει πολύ "φασαρία" (βασικά πολύ έντονες διακυμάνσεις στο ψυχοακουστικό μοντέλο του mp3). Ενώ το CBR θα θέσει ανώτατο όριο τα 192kbits το VBR μπορεί σε συγκεκριμένα σημεία να ανεβεί στα 256 ή και στα 320kbits ακόμα!
Τώρα βέβαια στην πράξη τα πράγματα διαφέρουν. Ειδικά σήμερα όπου ο αποθηκευτικός χώρος που διαθέτουμε είναι "τεράστιος" σε σχέση με την εποχή που διαδόθηκαν οι αλγόριθμοι CBR/VBR είναι 1000 φορές προτιμότερο να κωδικοποιούμε με υψηλό CBR παρά με παραπλήσιο VBR.
Ακόμα καλύτερο θα ήταν να μεταβούμε σε άλλο μη-απολεστικό αλγόριθμο (όπως το flac) αλλά αυτό είναι άλλη ιστορία!
Edit:
geposted Sun 05 Feb 12 @ 11:13 am
dld an epiasa kala to noima ta arxeia ixou vbr (kata kirio logo ta kenourgia komatia) isos proerxontai apo video... kai mallon ine anamfivolou poiotitas (youtube kata kirio logo).
geposted Sun 05 Feb 12 @ 6:02 pm
Όχι, δεν το έπιασες σωστά. Απλά αν κάνεις ΕΣΥ την κωδικοποίηση είναι προτιμότερο να χρησιμοποιήσεις CBR.
Τα μειονεκτήματα του VBR δεν έχουν να κάνουν τόσο με την ποιότητα ήχου που βγάζουν, αλλά με άλλα πρακτικά θέματα.
Και κάτι τελευταίο: Όλα τα αρχεία Video είναι VBR. Ο ήχος τους όμως μπορεί να είναι είτε CBR είτε VBR. (Ο ήχος στα αρχεία video κωδικοποιείται ανεξάρτητα απο την κινούμενη εικόνα. Έτσι η κινούμενη εικόνα είναι πάντα VBR ενώ ο ήχος είτε το ένα είτε το άλλο)
geposted Sun 05 Feb 12 @ 6:53 pm
ok:) euxaristw gia to frontistirio:P:P
geposted Sun 05 Feb 12 @ 7:11 pm
Gia osous yposthrizan oti ta Pioneer....MONO KAFE DEN FTIAXNOUN..
geposted Sun 05 Feb 12 @ 7:58 pm
Η επόμενη έκδοση....γνωστού dj software....xexexe....με νεο dedicated HARDWARE
geposted Sun 05 Feb 12 @ 10:14 pm
