Forum: Old versions
Topic: Virtual DJ Pro 7 & Numark Mixdeck Express
I have recently upgraded to VDJ Pro 7 and noticed that when playing music from my computer that I only have control of the gain on Ch 1. on the controller. Is that normal?
geposted Fri 13 Jan 12 @ 9:55 am
Iman3Home userMember since 2012
Hello,
I just got a numark mixdeck express which came with a serato dj intro. I tried mapping it to use the virtual dj pro 7 but only the mixer section works.
My configuration are as follows:
INPUT: None
OUTPUT: External mixer
SOUND CARD: ASIO4ALL
Finally I click apply and ok then tried mapping the decks and each time I select an option such as touch-wheel from the scroll down menu on the right side of the window and spin the platter some information are displayed but the deck does not respond if I press play from the software it works but if I press play from my controller nothing happens. Is there something I am not doing right?
Thank you
geposted Mon 13 Feb 12 @ 4:23 am
Most likely you are using an older version of the software that pre-dates native support for the Numark MixDeck Express. It's natively supported in the latest version and does not need mapping.
Please register your Pro serial number on the page http://www.virtualdj.com/users/edit.html and then download the latest version from http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html
You can test it before purchasing for 10 minutes at a time in VirtualDJ Home FREE: http://www.virtualdj.com/download/free.html
geposted Mon 13 Feb 12 @ 4:51 am
well there is nothing on the website that even mentions the mixdeck just the ns6 and 7 etc
geposted Mon 20 Feb 12 @ 10:04 pm
Please see both the hardware page http://www.virtualdj.com/products/hardware.html and the official list of supported controllers in the latest version of the software: http://www.virtualdj.com/wiki/VirtualDJ%20Controllers.html
You will clearly see the MixDeck listed there as well as others that the software supports. For registered licensed users there are also user-made mappers for unsupported controllers available from http://www.virtualdj.com/addons/controllers.html
Please download the latest VirtualDJ Home FREE from http://www.virtualdj.com/download/free.html and try it for 10 minutes at a time with the MixDeck. If you like VirtualDJ, please support the software by purchasing it: http://www.virtualdj.com/buy/index.html
geposted Tue 21 Feb 12 @ 5:07 am
I just got a mixdeck express and downloaded the newest update of virtual dj but it only has control with ch. 1
geposted Tue 21 Feb 12 @ 11:04 am
geposted Wed 22 Feb 12 @ 7:11 am
On the link you have listed is says mixdeck. will it work with mixdeck EXPRESS??
geposted Mon 28 Jan 13 @ 9:09 am
Will what work?
Both the Mixdeck and Mixdeck Express have native mapping in VDJ, so you can use either one as a controller & sound card/mixer for VDJ (full Pro version)
geposted Tue 29 Jan 13 @ 11:22 am
I need help setting and configuring my numark mixdeck and vdj pro
geposted Sat 01 Jun 13 @ 12:55 am
Please register your Pro serial number to your account http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
If your MixDeck came with VirtualDJ LE then it entitles you to a discount off the cost of upgrading (Assuming that it's not second hand and already used.)
Once you have done this, please see: http://www.virtualdj.com/wiki/MixDeck.html
geposted Sun 02 Jun 13 @ 11:31 am
spudd45Home userMember since 2011
I've been trying to register my mixdeck Express, but it's not excepting my serial number...this is BIG TIME Fustrating!.... I've even showed it to some people that knows how to download the program and can't figure out why its not working! CAN YOU PLEASE HELP ME! I'm ready to just use another program, as much as I want to use this, I'm losing patience.
geposted Thu 08 Aug 13 @ 7:36 pm
geposted Thu 08 Aug 13 @ 9:43 pm
esaumtzHome userMember since 2014
i have my mixdexk express , purchased the monthly plan for usind virtual dj 8 and im nit getting any sound on my headphones , can get it to configurate. Can someone help
geposted Wed 27 May 15 @ 8:19 pm
Show a screen shot of your audio config.
geposted Thu 28 May 15 @ 2:56 am
