NAMM 2012
Reloop Terminal Mix 4 Virtual DJ Edition
Comes 'Plug'n'Play' ready with 4-Deck Virtual DJ 7 LE (Reloop edition)
http://www.reloopdj.com/product_info.php/info/735
geposted Fri 13 Jan 12 @ 3:51 pm
ils commence a faire de belle chose reloop
geposted Fri 13 Jan 12 @ 3:54 pm
NAMM 2012
AKAI MPC STUDIO
http://www.akaiprompc.com/mpcstudio.php
geposted Fri 13 Jan 12 @ 3:56 pm
geposted Fri 13 Jan 12 @ 3:59 pm
J'ai le 750 et j'en suis très satisfait. Même si je préfère largement le Sennheiser HD-25.
geposted Fri 13 Jan 12 @ 4:28 pm
Idem
geposted Fri 13 Jan 12 @ 6:54 pm
J'ai le HD 25 aussi :) et il est à la perfection !
Dj Dorian
Dj Dorian
geposted Sat 14 Jan 12 @ 2:35 am
preview du probable futur Kontrol X-2 de NI:
geposted Sat 14 Jan 12 @ 3:34 am
http://www.geminidj.com/cdj-650
- Slot-in CD-ROM compatible with Audio CDs, CD-Rs, MP3-CDs
- USB input for USB storage devises
- MIDI and HID capabilities for use as a software contrôler
- Full-color 3.2\" TFT screen with contrast adjustment and waveform display
- 5\" touch-sensitive jog wheel with two selectable modes: Pitch Bend / Scratch Effect with Reverse
- PC/Mac Audio I/O interface (up to 24-bit/192kHz)
- Plays MP3, AAC, WAV and AIFF formats
- Stereo RCA output
- Three programmable Hot Cues for instant track playback points
- BPM functions including Auto (Sync), Manual (Tap), ID3 and BPM Lock
- Variable ptich control with six settings: +/- 4%, 8%, 16%, 24%, 50%, 100% and Master Tempo control
- Frame accurate search with buttons or jog wheel
- Seamless Loop with Reloop and Loop Adjust
- Anti-shock using RAM buffer memory
geposted Sat 14 Jan 12 @ 11:38 am
c'est marrant le design GEMINI me fait penser a une grand marque ,
mais je ne me souvient plus laquelle ,
CDJ aussi ça me dit quel que chose ,
je ne m'en souvient plus non plus ,
geposted Sat 14 Jan 12 @ 12:58 pm
Non !!! je vois pas ?!
geposted Sat 14 Jan 12 @ 1:27 pm
ça va surement me revenir
geposted Sat 14 Jan 12 @ 1:39 pm
NAMM 2012
NUMARK 4Trak
Bon prévue pour Traktor, pour l'instant.....
Caractéristiques :
- Contrôleur 4 Decks pour Traktor 2 de Native Instruments
- FX Kommand Console avec 12 potentiomètres pour les effets et les filtres de Traktor
- Section de mixage de 4 canaux qui fonctionne avec ou sans ordinateur
- 4 entrées de niveau ligne, 2 entrées pour platines vinyle et 2 pour micros
- Interface audio 24-bit avec sorties XLR symétriques
- Fonction Strip Search avec indicateur lumineux de la position dans le morceau
- 2 plateaux tactiles éclairés par LEDs bicolores
Caractéristiques :
geposted Mon 16 Jan 12 @ 9:54 am
en tous cas elle ont l'air tres design et fonctionnel ... a voir au SIEL peut etre....
cea dis la Reloop resemble a une fusion d'Hercules mx4 & Ego de chez Pioneer lol
geposted Mon 16 Jan 12 @ 11:31 am
D'après se que j'ai lu le prix de la NUMARK 4Trak sera fixé entre 860€ à 870€
http://www.delamar.de/dj-equipment-2/numark-4trak-13028/
geposted Mon 16 Jan 12 @ 4:46 pm
860 à 870
ou
860 à 970 ?
geposted Mon 16 Jan 12 @ 11:27 pm
Le dolard bouge énormément (1099 US$ = 851.517).
geposted Tue 17 Jan 12 @ 4:26 am
CDJ WHITE Edition
geposted Thu 19 Jan 12 @ 9:43 am
NAMM 2012
Dj Tech Dragon Two
Caractéristiques :
Mode 2/4 decks
Section de mixage intégrée avec Filtre analogique sur chaque canal
Interface audio 4 x 4 avec drivers ASIO
Sorties Master symétriques sur XLR
Sorties Booth sur RCA
2 entrées stéréo Phono/Ligne pour source audio externe
Accès direct à 4 samplers
24 pads en caoutchouc pour accéder directement aux contrôles de transport, boucle et cue
2 molettes Jog tactiles entourées de LED
Crossfader
Châssis en aluminium brossé
Logiciel Virtual DJ LE inclus
Caractéristiques :
Mode 2/4 decks
Crossfader
geposted Thu 19 Jan 12 @ 10:21 am
Numark IDJ PRO
Numark MpcDj
Numark MpcDj
geposted Thu 19 Jan 12 @ 1:04 pm
