I am using VDJ as a tool for conducting large ensembles and it is fantastic! Is there a way to add more than 10 cue points in a file? It would be beneficial as a large work may be 20 minutes with 30-50 rehearsal marks (or more). It has made score study much easier to digest!
geposted Tue 17 Jan 12 @ 2:35 pm
VDJ supports up to 99 cue points but it is skin dependant. For most people 10 is more than enough.
If you're not a registered user then you don't have access to custom skins I'm afraid.
Keith
Keith
geposted Tue 17 Jan 12 @ 2:45 pm
you can have up to 99 cue points in a track... I made you two button mappings that set the next cue and delete the last cue for the first 50 cues. you can map the keyboard in vdj home, however to use midi controllers you need vdj pro
set cue's
hot_cue 50 ? set_cue 51 : hot_cue 59 ? set_cue 50 : hot_cue 48 ? set_cue 49 : hot_cue 47 ? set_cue 48 : hot_cue 46 ? set_cue 47 : hot_cue 45 ? set_cue 46 : hot_cue 44 ? set_cue 45 : hot_cue 43 ? set_cue 44 : hot_cue 42 ? set_cue 43 : hot_cue 41 ? set_cue 42 : hot_cue 40 ? set_cue 41 : hot_cue 39 ? set_cue 40 : hot_cue 38 ? set_cue 39 : hot_cue 37 ? set_cue 38 : hot_cue 36 ? set_cue 37 : hot_cue 35 ? set_cue 36 : hot_cue 34 ? set_cue 35 : hot_cue 33 ? set_cue 34 : hot_cue 32 ? set_cue 33 : hot_cue 31 ? set_cue 32 : hot_cue 30 ? set_cue 31 : hot_cue 29 ? set_cue 30 : hot_cue 28 ? set_cue 29 : hot_cue 27 ? set_cue 28 : hot_cue 26 ? set_cue 27 : hot_cue 25 ? set_cue 26 : hot_cue 24 ? set_cue 25 : hot_cue 23 ? set_cue 24 : hot_cue 22 ? set_cue 23 : hot_cue 21 ? set_cue 22 : hot_cue 20 ? set_cue 21 : hot_cue 19 ? set_cue 20 : hot_cue 18 ? set_cue 19 : hot_cue 17 ? set_cue 18 : hot_cue 16 ? set_cue 17 : hot_cue 15 ? set_cue 16 : hot_cue 14 ? set_cue 15 : hot_cue 13 ? set_cue 14 : hot_cue 12 ? set_cue 13 : hot_cue 11 ? set_cue 12 : hot_cue 10 ? set_cue 11 : hot_cue 9 ? set_cue 10 : hot_cue 8 ? set_cue 9 : hot_cue 7 ? set_cue 8 : hot_cue 6 ? set_cue 7 : hot_cue 5 ? set_cue 6 : hot_cue 4 ? set_cue 5 : hot_cue 3 ? set_cue 4 : hot_cue 2 ? set_cue 3 : hot_cue 1 ? set_cue 2 : set_cue 1
delete cue's
hot_cue 51 ? delete_cue 51 : hot_cue 50 ? delete_cue 50 : hot_cue 49 ? delete_cue 49 : hot_cue 48 ? delete_cue 48 : hot_cue 47 ? delete_cue 47 : hot_cue 46 ? delete_cue 46 : hot_cue 45 ? delete_cue 45 : hot_cue 44 ? delete_cue 44 : hot_cue 43 ? delete_cue 43 : hot_cue 42 ? delete_cue 42 : hot_cue 41 ? delete_cue 41 : hot_cue 40 ? delete_cue 40 : hot_cue 39 ? delete_cue 39 : hot_cue 38 ? delete_cue 38 : hot_cue 37 ? delete_cue 37 : hot_cue 36 ? delete_cue 36 : hot_cue 35 ? delete_cue 35 : hot_cue 34 ? delete_cue 34 : hot_cue 33 ? delete_cue 33 : hot_cue 32 ? delete_cue 32 : hot_cue 31 ? delete_cue 31 : hot_cue 30 ? delete_cue 30 : hot_cue 29 ? delete_cue 29 : hot_cue 28 ? delete_cue 28 : hot_cue 27 ? delete_cue 27 : hot_cue 26 ? delete_cue 26 : hot_cue 25 ? delete_cue 25 : hot_cue 24 ? delete_cue 24 : hot_cue 23 ? delete_cue 23 : hot_cue 22 ? delete_cue 22 : hot_cue 21 ? delete_cue 21 : hot_cue 20 ? delete_cue 20 : hot_cue 19 ? delete_cue 19 : hot_cue 18 ? delete_cue 18 : hot_cue 17 ? delete_cue 17 : hot_cue 16 ? delete_cue 16 : hot_cue 15 ? delete_cue 15 : hot_cue 14 ? delete_cue 14 : hot_cue 13 ? delete_cue 13 : hot_cue 12 ? delete_cue 12 : hot_cue 11 ? delete_cue 11 : hot_cue 10 ? delete_cue 10 : hot_cue 10 ? delete_cue 10 : hot_cue 9 ? delete_cue 9 : hot_cue 8 ? delete_cue 8 : hot_cue 7 ? delete_cue 7 : hot_cue 6 ? delete_cue 6 : hot_cue 5 ? delete_cue 5 : hot_cue 4 ? delete_cue 4 : hot_cue 3 ? delete_cue 3 : hot_cue 2 ? delete_cue 2 : hot_cue 1 ? delete_cue 1 : nothing
Unfortunately there is no way to jump to the next cue wit one button, so if you want to trigger them you will need a matrix controller.
set cue's
delete cue's
geposted Tue 17 Jan 12 @ 3:50 pm
How do you delete a cue in the mac Version?
geposted Thu 22 Nov 12 @ 2:55 pm
http://www.virtualdj.com/wiki/Forum%20Rules.html
Just use the two finger action to delete the cue point inside the waveform or the skin cue point buttons.
Quote :
>Do not 'hijack' a topic by posting a message or question that is not related to the topic in any way. If you wish to post an unrelated message, please open your own new topic in the appropriate forum (Click on the pen and paper icon at the top of the forum topic list.)
>Do not bump an old topic that is more than 1 year old. Old topics may no-longer be relevant to the current version of the software. Please open your own new topic in the appropriate forum.
geposted Fri 23 Nov 12 @ 2:43 am
