Dear tech support,
I recently got a Icon Idj and have been trying to map it to VDJ
http://www.icon-global.com/ShowPro.aspx?ID=98
Set up i-DJ, in Virtial DJ [simple MIDI Wrapper] has been confirmed.
I completed a set of MIDI, and crossfader play button was working properly.
I check the signal MIDI, could set up outside wheel well.
However, I am having trouble scrach. music and video work by turning the wheel.
Moreover, under the url below is watching.
http://www.virtualdj.com/forums/158474/Hardware_Technical_Support/Icon_Idj_Scratch_wheel_problem.html
setting -> Mappers [key:0-107](right deck.leftdeck is 0-108).
Action [deck right touchwheel]
In order to successfully operate wheel [Action] Please let me know what I have written to at.
In addition, i-DJ is fine with it running tractor, a problem of Virtual DJ
geposted Fri 20 Jan 12 @ 9:50 am
You can map it easily with Virtual DJ v5.
geposted Thu 09 Feb 12 @ 8:51 am
your in luck, I just uploaded an absolutly insane mapping for the idj using every little trick I could think of, there was an issue in uploading it but it should be good to go very soon as I just sent it in again then, if you don't like the over the top mapping you can just make your own as there is a working definition file included.
geposted Thu 09 Feb 12 @ 9:02 am
can any one point me to the iCon iDJ mapping please
geposted Tue 20 Mar 12 @ 8:33 am
it's still pending review for some reason, not sure why... but pm me your email and i'll send it to you, if your keen to let me know what you think of it.
http://www.virtualdj.com/homepage/synthet1c/blogs/4680/Icon_Idj_Pocket_Controllerist_Manual.html
geposted Tue 20 Mar 12 @ 9:01 am
Hello synthet1c,
I need the icon mapper iDJ, you could tell me how to do it or send it to me?
thank you very much.
[eMail removed]
[Sorry, contact details are not allowed from unlicensed users.]
[eMail removed]
![](http://www.virtualdj.com/image/95245/43490/stop.png)
geposted Mon 25 Jun 12 @ 6:42 am
The files are already released here: http://www.virtualdj.com/addons/14397/iCON_iDJ.html
Greets, Heiko
Greets, Heiko
geposted Mon 25 Jun 12 @ 7:04 am
hi how can i run ICON idj with virtual dj
can i map using vdj 5
geposted Wed 24 Oct 18 @ 4:02 pm
