jabo65 wrote :
Can I use Mixed in Key with VDJ8?
Yes. If you're detecting and writing keys with MIK then make sure the 'useKeyFromTag' VDJ option is set to 'yes', so that VDJ will use the tagged key instead of its own analysis.
jabo65 wrote :
Will it auto set cue points and have them transfer/translate into VDJ?
It will auto set them (it's rubbish at it) but it only writes Serato or Traktor data. However, if you set VDJ to 'getCuesFromTags' then they should import.
You'll probably find that it's far better to set them yourself manually...
geposted Sat 17 Feb 18 @ 9:41 am
Definitely use your own cue points
geposted Sat 17 Feb 18 @ 2:51 pm
