hello, i have a problem : i'm trying to do a video mix but any type of video file I am playing, it runs like hell. Audio is fine but video is decalated and looks like it freezing from time to time. Also when i start one video in one deck i have another problem : video is black, audio is ok, after 30 seconds video appear but still running slowly and freezing. I am running Windows 7 Enterprise/32 bit on a Intel Core I3-2330M CPU @ 2.20 Ghz with 4 G of Ram and i have a Radeon 5400 with 1 G dedicated Ram. Is it not enough ? Any help will be much appreciated...
geposted Wed 08 Feb 12 @ 11:56 am
Look here for solutions:http://www.virtualdj.com/forums/105257/PC_Version_Technical_Support/_DPC_Latency_Checker_(_THESYCON)_Helped_Me_Fix_My_Audio_Problems___.html
Good Luck.
Joey...
Good Luck.
Joey...
geposted Wed 08 Feb 12 @ 12:07 pm
I got this message in DPC : This machine should be able to handle real-time streaming of audio or video data without drop-outs. But still the drops are here :(
geposted Wed 08 Feb 12 @ 12:19 pm
Okay then, try this program there may be some background services that are creating this issue:http://www.iobit.com/gamebooster.html
geposted Wed 08 Feb 12 @ 12:49 pm
Help!
My music video's were working fine and recently they will start to play and my computer completely freezes up. I have no controls and cant even get into my taskmanager. I have to hard reset.
if anyone can help let me know
geposted Sun 11 Mar 12 @ 7:51 am
Do the video effects work, like Sonique, slideshow, etc.
Are they all the same type of file?
Do they play okay from a different player?
geposted Sun 11 Mar 12 @ 7:59 am
Videos play out of SYNC with their audio. I am using a Macbook Pro i7 with 8 gigs of Ram. Videos play fine outside of virtual DJ. Can someone show me how to have Video and Audio Synced all the time?
Thanks..!
Thanks..!
geposted Mon 26 Mar 12 @ 2:51 pm
Im trying to record my video mixes...while mixing it seem fine but when i play it back the video effects are freezing; the sound is fine though. any ideas to how to fix this? AND during my play back you can hear me Cuing up my next video & mix...what am i doing wrong?
geposted Wed 25 Apr 12 @ 4:46 pm
I am seeing a similar problem. I thought it was my old laptop getting slow. I have a new ASUS with 2.2Gz i7, 8GB ram and an NVIDIA GT555M with 2GB dedicated video ram so why are my videos on Virtual DJ still freezing up as they are playing when on QuickTime or other player on same laptop they run flawlessly. We not only use VirtualDJ for DJ'ing buit also for running corporate and other presentations over plasma and projection screens. I really hope you guys have a solution for this.
geposted Thu 17 May 12 @ 11:30 pm
I've posted this somewhere else, but have you tried checking the box that says "decode while hidden" in the video options?
Had the same problem, fixed! Never have had that issue again.
geposted Fri 18 May 12 @ 4:46 pm
Look Here for some answers to performance issues http://www.virtualdj.com/forums/105257/PC_Version_Technical_Support/_DPC_Latency_Checker_(_THESYCON)_Helped_Me_Fix_My_Audio_Problems___.html
Good Luck,
Joey....
Good Luck,
Joey....
geposted Sat 19 May 12 @ 5:09 pm
i having a problem with mixing video on virtual dj..now im running 8 gigs of ram with i 3 core audio loads fine the video loads late and i even changed the format of the video to vob ..same problem any ideas...and its freezing please help!!!!!
geposted Sat 09 Feb 13 @ 1:36 pm
What video card?
geposted Sat 09 Feb 13 @ 2:52 pm
Hi everybody, please i need help!! I have problem when i press hardware aceleration on video setting, the video start goes wrong, audio run okay.. Please help me someone i am desperate I do not know what to do with it. Thanks a lot
geposted Fri 08 Mar 13 @ 9:10 am
Videos MP4 run too slow in Virtual DJ 8, but the same videos runs well in Virtual DJ 7.
geposted Sat 21 Mar 15 @ 7:20 am
Please do not open Treads that old. It's about 2 years old and i don't think your problem is anyway related to version 7.05.
Please feel free to reopen a new Thread about your problem.
Thanx,
Heiko
Thanx,
Heiko
geposted Mon 23 Mar 15 @ 12:47 am
