na rwtisw kati?
vgike i vms4 me ta gnwsta provlimata stis ekdodous tis kai meta vgikan taytoxrona i vms2 me ti vms4-traktor edittion kai argotera i 4.1
stin vms4-traktor edition eixan lythei tha provlimata ixou?thewrw pws logika nai kathws vgike mazi me ti vms2
geposted Tue 11 Dec 12 @ 5:36 pm
Oxi,
prota h Vms ksi h vms traktor (idio hardware), kai meta h vms2 kai 4.1 (tautoxona)
ps. mou esteiles ena pm, edo tha me breis pio eukola.
geposted Tue 11 Dec 12 @ 5:50 pm
sxetika me afto ithela na se rwtisw Giwrgo kai epeidi den mou aresei na milaw gia Traktor sto episimo forum tou VirtualDj (posi anoxi na deiksete kai eseis...) gia ayto epeleksa na kanoume ti syzitisi afti ektos forum.
Sto site tis American Audio i sygkekrimeni konsola paroti panw deksia grafei VMS4, stin analytiki perigrafi tis etairias grafei VMS4.1 Traktor Edittion
http://www.adjaudio.com/ProductDetails.aspx?ItemNumber=1462&MainId=1&Category=23
Einai to kalytero value for money sta lefta pou ti vrika kai dn thelw na exw provlimata se master out kai headphones...
EDIT:kai sta specs tis ta audio features einai idia me ayta tis 4.1
yparxei anthrwpos tis AA ston opoio na mporoume na apefthynthoume gia dieykriniseis?
geposted Tue 11 Dec 12 @ 6:06 pm
http://www.americandj.eu/default/vms4-traktor.html
Η VMS4.1 traktor έχει δύο διαφορές σε σχέση με τις VMS4 & VMS4.1 VDJ στο interface της. Έχει αποκλειστικά κουμπία για εναναλλαγή των decks και το play-pause βρίσκεται στο ίδιο κουμπί. Στείλε εδώ http://www.americandj.eu/default/contacts τις ερωτήσεις σου και θα σου απαντήσουν σύντομα.
geposted Wed 12 Dec 12 @ 12:53 am
Apo oso ksero einai stin proti partida me tin proti vms4 ara exei ta idia problimata.(para to onoma pou moiazei)
H vms2/4.1 kykloforisan meta poly argotera, kai malista kanan kai ena party gia auto.
Leksi kleidi pou diafimizoun (to fix stto kykloma tou hxou) einai to “DSP D-Core” Audio Engine. Stin vms2/4.1
"comes with American Audio’s exclusive “DSP D-Core” Audio Engine inside."
An den to grafei auto einai apla h proti vms4.
geposted Wed 12 Dec 12 @ 10:08 am
Γειά χαρά σε όλους.Γιά να μην ανοίγω άλλο topic,θα ήθελα να ρωτήσω γιά την vms2.
1.Αν μπορεί να {φόρτωσει} έναν τελικό ενισχυτή χωρίς τη χρήση μίκτη.
2.Γενικά τι παίζει με τον ήχο της , τον ήχο στα ακουστικα και το μίκροφωνο.
Ετσι ώστε να αποφύγω τον εξωτερικό μίκτη.
Ευχαριστώ εκ των προτέρων.
geposted Mon 17 Dec 12 @ 7:19 pm
Θα χρειαστεί να γίνεις λίγο πιο σαφής:
Και το κινητό σου μπορεί να {φόρτωσει} ένα τελικό ενισχυτή, χωρίς τη χρήση μίκτη!
Πώς θα σ' εξυπηρετούσε ο εξωτερικός μίκτης, οσον αφορά στον ήχο, στ' ακουστικά και στο μικρόφωνο;
Ουσιαστικές πληροφορίες, ώστε να σε βοηθήσουμε άμεσα και αποτελεσματικά:
α) Τι κάνεις;
β) Τι θέλεις να επιτύχεις;
γ) Από που προκύπτουν οι ενδοιασμοί που έχεις περί τελικών ενισχυτών, ήχου στ΄ακουστικά και στο μικρόφωνο;
dj-gatos wrote :
2.Γενικά τι παίζει με τον ήχο της , τον ήχο στα ακουστικά και το μίκροφωνο.
α) Τι κάνεις;
geposted Mon 17 Dec 12 @ 7:49 pm
dj-gatos αν κατάλαβα σωστά, θες να ενώσεις κατευθείαν ηχεία στη VMS2, τότε ναι μπορείς καθώς δουλεύει και σαν αναλογικός μίκτης χωρίς τη χρήση λογισμικού. Όσο αφορά την ένταση των ακουστικών δεν διάβασα κάτι αρνητικό. Τα παιδιά που έχουν τη VMS2 σίγουρα θα μπορούν να σου δώσουν μια καλύτερη εικόνα.
geposted Tue 18 Dec 12 @ 1:33 am
Φιλε Dee P μη μπερδευεσαι.Ειναι δυο διαφορετικες ερωτησεις σχετικα με την vms2.
1.Αν μπορω να παιζω μουσικη με λαπτοπ-vms2-τελικο ενισχυτη-ηχεια.[εννοω χωρις την ενδιαμεση χρηση μικτη].
2.Αν η vms2 εχει καλο ηχο στην εξοδο.
Αν εχει δυνατο ηχο στην προακουστικη [δηλ.στα ακουστικα].
Αν η εισοδος του μικροφονου εχει καλο ηχο [δηλ.να κανω μια ανακοινωση].
Παιζω μουσικη σε γαμους βαφτισεις κ.τ.λ.
Με αλλα λογια θελω να καταργησω το μικτη.
geposted Tue 18 Dec 12 @ 2:40 am
Quote :
Two small toggle switches on the front select between USB audio and line/phono inputs. The unit can act as a standalone mixer (ie no need for a laptop), so you set these to “analog” and can then DJ away old school-style with CDJs or turntables.
http://www.digitaldjtips.com/2011/09/review-video-american-audio-vms2-dj-controller/
geposted Tue 18 Dec 12 @ 3:20 am
Ναι!
Quote :
Ναι, ικανοποιητικό για τις περισσότερες χρήσεις!
Quote :
Δεν θα αντιμετωπίσεις πρόβλημα επειδή η ένταση στην έξοδο των ακουστικών είναι χαμηλή.
Quote :
Υπήρχε ένα θέμα στο παρελθόν με τη VMS4, το οποίο όμως κατόπιν διορθώθηκε με τη VMS4.1 και τη VMS2. Οπότε είσαι οκ!
geposted Tue 18 Dec 12 @ 3:35 am
Dee P φιλε ευχαριστω πολυ.
geposted Tue 18 Dec 12 @ 5:58 am
dj-gatos έγραψα κάτι διαφορετικό από τον Dee P ή κάτι που δεν κατάλαβες? :-|
geposted Tue 18 Dec 12 @ 7:18 am
DjKikas83 Tο καταλαβα.Σε ευχαριστω για την απαντηση.
Σκεφτομαι να την αγορασω.
geposted Tue 18 Dec 12 @ 8:14 am
εχθες αγορασα την vms4.1(δωρο της αραβωνιαστικιας μου :-)
εχω ενα προβλημα....το οποιο διμιουργητε μονο με την pro εκδοση 7.3 και οχι με την le που συνοδευει την κονσολα....λοιπον ενω κουναω το αριστερο volume fader στην οθονη δεν κουνιετε αλλα αντι αυτου κουνιετε το crossfader ! το δεξι volume fader συμπεριφερετε κανονικα δηλαδη οταν το κουναω κουνιετε και στην οθονη. το crossfader επισης οταν τομ κουναω κουνιετε κανονικα στην οθονη..... το ιδιο περιπου προβλημα ειχα και με την vms4 οταν περασα το 7.3 πιθανων....
θα ηθελα να ρωτισω τουσ ειδικουσ του φορουμ τι πρεπει να κανο....να περασω μηπως παλι το virtual dj 7 χωρις το update an γινετε? εχετε ακουσει και απο αλλουσ κανα τετοιο θεμα? εχω κανει κατι λαθος εγω?
κλεινοντας θα προσθεσω πως με μια πρωτη δοκιμη ειδα πως οτι προβληματα ειχε η vms4 δεν υπαρχουνε ποια.
geposted Tue 18 Dec 12 @ 8:25 am
Δοκίμασε να πας στο Config, μετά Mappers. Πάτα Key learn και μετά κούνα το Fader. Τί Action δίνει;
geposted Tue 18 Dec 12 @ 10:41 am
to patisa kai mou grafei
key learn ch2_vol kai apo kato sto action learn grafei
fake_crossfader & video_crossfader
geposted Tue 18 Dec 12 @ 10:44 am
Ορίστε η απάντηση σου! Δοκίμασε το ίδιο με το άλλο volume fader που δουλεύει σωστά. Τι λέει;
geposted Tue 18 Dec 12 @ 10:50 am
key learn ch3 vol
action learn deck 2fake _ level
geposted Tue 18 Dec 12 @ 10:59 am
Αντικατέστησε στο κανάλι που δεν δουλεύει σωστά το fake_crossfader & video_crossfader με deck 1fake _ level . Οκ τώρα;
geposted Tue 18 Dec 12 @ 11:04 am
