Ok, I just got a dj2go so that I can use it instead of my mixtrack when I am doing small things.... Here is what I'm wanting to do & not sure if it's possible but figured I would ask here..... DJ2Go as the controller & my digidesign mbox2 as the sound card... I have it 2 where the output is coming out of the mbox2 but the issue is cueing in the headphones because the mbox 2 does have a headphone output but it plays the same thing as what's coming out of the master output....not sure if there is a setting in VDJ that I just can't find that might change that or not. & my other issue is that I can't do a manual backspin with the dj2go it just pitch bends....I know it can do a manual one because I did it once & not sure what button I pressed 2 make it not do it anymore....Any help is appreciated
OH also if I can't cue with my MBOX2 what would be the least expensive i/o box that I could cue with....
geposted Sat 25 Feb 12 @ 6:14 pm
I would use my laptop sound card for the headphone output & the external sound card for the master output. You have to set it up in config/sound setup, or another way I do it is to use usb headphones.
geposted Sun 26 Feb 12 @ 12:11 am
I tried setting it up under advance config main outputs digidesign mbox & headphone built in output but it gave me a error & gave me the spinning rainbow & crashed vdj
geposted Sun 26 Feb 12 @ 12:24 am
What is your system config? OS, ect???
geposted Sun 26 Feb 12 @ 8:12 pm
Do you have the MBox running on ASIO? Your internal card is probably not. ASIO and WDM don't match and will give you errors. If you want to use both card, you have to switch your MBox to WDM. First setup the MBox on the MBox configuration Menu before you start VDJ, then choose the proper driver in VDJ.
geposted Sun 26 Feb 12 @ 8:26 pm
Mac OSX & Martin I will try that...
geposted Sun 26 Feb 12 @ 8:35 pm
