Forum: Old versions
Topic: VMS2 Recording Cross Fader
Hi,
Having some issues with the recording. Every time i record a mix, the recording plays the mix as though the cross-fader is always in the middle. So you can hear both sides even though on the console and the software the crossfader is on one side. Why is this happening? Could you please HELP ME! thank you much appreicated
geposted Sun 26 Feb 12 @ 10:21 am
VMS2 has a real analogue mixer, and even though it sends midi signals so that you can see the sliders moving on the screen, you need to follow this way to record properly .. http://www.virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
If your VMS2 came with VirtualDJ LE software, please register that to your Profile Page http://www.virtualdj.com/users/edit.html
http://www.virtualdj.com/wiki/Why%20must%20I%20register%20my%20serial%20number%20in%20my%20profile.html
Thanks for that. I am not using a sound card and the VMS2 does not have a REC OUT output. I am using the booth output. Where does the other end of the cable go in my amp (using RCA cable)? Sorry i know this is probably a stupid question!
oh, got the VMS2 second hand! didnt get LE virtual dj!
i have to agree
recording from the VMS work stations turned out to be a week long nitemare for me too :(
eventually sorted after hours on Google
Conclusion
Ignore VDJ recording side of software
Do not take Booth out to line in of pc/mac sound card
Purchase a stand alone digital pocket recorder (Yamaha C24) or similar
Plug Booth out put from VMS directly into Pocket recorder line in............. Jobs a good un
Results
The biggest problem i found with plugging directly in the pc sound card was the hiss, feedback general background noise.
After disconnecting everything from the pc, just leaving bare bone hardware i could not locate or eliminate the background noise that was still present.
I even went to the extremes of disconnecting the soundcard, USB buses & rebooting said hardware & still no difference
I pondered for a while on the old school way of recording, decks, mixer, amp output to tape deck. Noisey but exceptable until DAT arrived.
After a bit more searching of Google i located the C24 (B Stock £80)
After setting up the small device, simple on screen menu, i banged out a short mix
Transferred to pc, pressed play & wow, better than wow
Even on C24's lowest recording setting (mp3) the mix was more than exceptable for toasting to cdr :)
So anyone else having recording issues with the VMS try this method
Marceegee
Technic 1200L vinyl / Timecode
Pioneer CDJ
Korg Kaos
VDJ 7 pro
Cubase 6
Yamaha C24
acw_dj wrote :
Hi,
YOu can record using a VMS2 or VMS4 if you are a pro full license user.
You can just BOOTH OUT to MIDILOG2 and use Advanced Audio Configuration
PLug a cable from the booth out to the MIDILOG2 in the VMS and ot works fine.
Deck1 - ADJ ASIO (ASIO) - OUT 1-2
Deck2 - ADJ ASIO (ASIO) - OUT 3-4
MIC - ADJ ASIO (ASIO) - LINE IN 1-2
RECORDLOOPBACK - ADJ ASIO (ASIO) - Line 3-4
It works perfect, no noises or glinches.
**** Pro Full User Level *****
this is ok if your midilogs are not all ready occupied ;)
guys i did it by the way acw_dj did but there are a lot of noises and bad scratches! how can i fix this?
which program did you use to record it...?
We have repeated quite a few times, that internal recording (using Record Loopback) is not recommended for the VMS2/VMS4/VMS4.1 units ,as it doesnt provide good results all times.
If you have sound quality issues with the way you have tried, maybe you should consider trying the secure path, and use a 3rd party application to record the Master or Booth Output of the VMS
Could you please tell me the solution to my problem ? When I record with my VMS2 on Virtual DJ LE 7 and i lower the sound a music in one of my deck with the channel fader, i hear the sound lower in my headset. But when i listen to the mix after i finish recording , the music didnt lower. Is there an option to when i lower a channel fader it lower in my headset and in the recording itselft ? thanks
