Forum: VirtualDJ Plugins
Topic: Change crossfader curve with a button?
Hey, I was just wondering if it is possible to switch between 2 crossfader types by pushing a button on a controller? I mean something along the lines of
button active crossfader_curves "scratch"
button not active crossfader_curves "full"
Would anyone have any idea what the code would be if it is possible?
(I wasn't sure if there was a general thread for coding enquiries so I'm sorry if this is in the wrong place!)
Thanks
geposted Sat 03 Mar 12 @ 11:45 am
Here's from the Wiki,
crossfader_curve : select the curve of the crossfader. enter a value to adjust the slope from a X curve (0%) to a inverted-U curve (100%). you can also specify common curves by name ("smooth", "full", "scratch", "cut", "disabled"). or you can draw your own curve, using a syntax like 'crossfader_curve "0=[1,0]/0.5=[1,1]/1=[0,1]"'.
Try just mapping 2 buttons with,
Crossfader_curve 'full'
Crossfader_curve 'scratch'
Hope that helps
Huey
geposted Sat 03 Mar 12 @ 1:12 pm
Or you can map it to a single toggle button using the following:
crossfader_curve 'full' ? crossfader_curve 'scratch' : crossfader_curve 'full'
geposted Sun 04 Mar 12 @ 10:01 am
Thats exactly what I was looking for, thanks for the help!
geposted Mon 05 Mar 12 @ 11:09 am
