I have numark IDJ3/MacBook Pro/Virtual DJ Pro fully updated. I need help figuring out how to configure my system so that the current playing track plays out of the speakers but I'm able to preview the next track in my headphones. I know there is a way to do it and I've played around with the config settings but keep striking out. Can someone assist me or point to a forum that explains it?!
Thanks
Thanks
geposted Mon 12 Mar 12 @ 3:10 pm
geposted Mon 12 Mar 12 @ 3:15 pm
Thank you! I gave it a shot and both songs play through my headphones? It automatically switched my outputs to Master: First sound card/Headphones second sound card. With no other options. For the Sound Card I have 2 cards selected, with IDJ3 selected for both as the description says.. I didn't hook my system up to a stereo, as Im just using sound from my computer until of course I go to my gig. Not sure if that changes anything?
geposted Mon 12 Mar 12 @ 4:20 pm
Playing around with it, I have this setup Inputs:none Outputs:Headphones Master-first card/Headphones-second card. SoundCard 2 cards:Built-in Output for option 1 and iDJ3 for option 2 and it seems to be working....just want to make sure I'm alright using this set up, as its different than descriped in the forum. Let me know your thoughts!
geposted Mon 12 Mar 12 @ 4:29 pm
Yes, the setup is right as u wrote. There was a mistake on the link I quoted, wich was revised already.
geposted Mon 12 Mar 12 @ 7:54 pm
awesome, thank you for the help!!
geposted Mon 12 Mar 12 @ 9:23 pm
