Forum: Old versions
Topic: Shift key
sout16Home userMember since 2003
Hi, been messing around trying to change the "press" of my shift key on a Mixtrack pro,
Basically i want it to work like a shift key on a keyboard, hold it down and tap the hotcues to delete them, how do i go about doing this?
regards
Paul
geposted Thu 15 Mar 12 @ 9:15 pm
if you mean you want a momentary shift you can change the mapping from "toggle 'shift'" to "set 'shift' while_pressed"
the action to delete the cues is already mapped in, but if you want to add shift functions to any other controls you can use this as a template
var 'shift' ? shifted action : normal action
eg if you wanted the play button to load a track when shifted, you could use this
var 'shift' ? load : play_pause
or if you wanted the jog to be a filter you could use this for the jog
var 'shift' ? param_greater 0 ? filter +0.01 : filter -0.01 : touchwheel
and this for the touchpad
var 'shift' ? down ? nothing : filter 50% : touchwheel_touch
there is a heap of things you can do, check out the wiki for everything
geposted Thu 15 Mar 12 @ 10:04 pm
cheers synthet1c, you my friend are a genuinely helpful and knowledgable guy, I read through loads and loads of topics which you had the answer for, and several of them helped me along also!
I was trying several different ways of entering "shift while_pressed" but just wasn't doing what i wanted, and the blue : red breakdown explains things better for me to, finally getting my head around how this programming works now!
so until my next question (which i think is an LED one!)
Thanks again!
Paul
geposted Fri 16 Mar 12 @ 6:22 am
Always happy to help as im an uber nerd when it comes to mapping.. In regard to your problem it needs to say the whole next line
the syntax used is important...
for the leds it works the same way
you have the the normal shift script, but in the true and false part you are asking another variable of the action the button the led belongs to is meant to perform.
var 'shift' ? loaded ? blink 400ms : off : play ? on : off
geposted Fri 16 Mar 12 @ 6:54 am
I've been reading the Manual and VDJ Pedia,commands, verbs,etc, can I map a shift button, but not as press and hold button, but like a toggle on/off shift key? I would like use the 4 preset buttons on my SCS1m mixer to switch between Deck Transport Commands, Loops , and FXs.
is this possible??
thank you
geposted Thu 22 May 14 @ 7:01 pm
