Forum: Old versions
Topic: Typhoon/VDJ
I cant seem to get my head around why VDJ just crashes now & then around 3 hours of mixing live?
done & read most things:
typhoon should be at 768ms
wifi off
Anti virus off
it wont even shut down?
Cpu meter is low
m11x 3r
£160 SSD
i5
Getting really annoyed now done it twice live?
Is cause the vestax typhoon is crap? & VDJ LE install_virtualdj_le_typhoon_v7.0.2.exe
I want to upgrade but hmmm
Any Other people have this ramdom crash?
please help
geposted Mon 26 Mar 12 @ 12:19 pm
yessssssss i have too mate, i think for the first 2 crashes i was using usb 3.0 but i have put it 800ms disabled wifi in device and turned off aniti virus and bluetooth mouse.
yep i was going to upgrade aswel but whats the point? i want to know whats up with either vdj le or tyhpoon?
try usb 2.0... and maybe increase the latency to see what happens... if your not using le it could be a bad effect or something... but send your crashgaurd report into support so they can see the cause and help you find a solution..
...and did you just reply to yourself in the third person? LOL
lol i copied & pasted it on wrong section oh wel, got mate who uses m11x too, what lappy you got
how you find the crash guard?
lets just say not an alienware lol.... crashgaurd report is TXT doc in the virtualdj folder in "my documents"
