I wish it would be possible to connect 2-4 Pc´s, each with their own controller of course, for mixing in a team and still having autosync.
You just choose a Master for the Tempo and get this clock send to all the other instances - not nescessary to see the other waveforms, maybee helpfull to see the beats patterns.
Well 2 would be enough for the most of us, as we like to do Dj-teams. so everybody can play with his own controller, own headphones, own database and music - and still you would create a mix together.
It´s actually only nescessary to send the beat clock / beat patterns in between the instances. The rest you could or better must Mix with an extra Mixer outside of vdj, where you probably also have to record it if you want to do so.
In the Config it might be nescessary to add a delay control, for faster and slower connections to keep the latency lag closed.
Any chance for having this option in VDJ8?
anyways thanks for a wonderfull programm, easy to use and still powerfull to make unique stuff!
geposted Tue 27 Mar 12 @ 7:10 am
