Forum: Old versions
Topic: USEING DMC-1 WITH VDJ HELP
I bought a dmc1 controller and I'm having some problem useing it,Vdj locks up when I try to use the pitch/cue memory/rev-fwd search,why the wait list and the shift button don't work ?.and why do I have to still use my mouse to high light a song to load it in player A or B, some need to be done to keep track high lighter on all the time like all the rest of dj software does.please help or can some updateing be done,thank you
geposted Sat 06 Sep 03 @ 4:48 pm
Here is how the DMC1 works with Virtual DJ:
Internal wheel: scratch
External wheel: seek
Load + Internal weel: search for a song and load it
Load + External wheel: search in directories
"Cue memory" (back and forward): change loop length
Group: loop on/off
Preview: beatlock on/off
Match: sync
Cue: when played, it stops and comes back to cue 1. when stopped, it sets the cue 1
Play: play/pause
Hope that helps :)
WOW! Thanks for posting that! I had no idea you could load tracks. I will try that as soon as I get home!
We need more good information like that in a FAQ
