Forum: Old versions
Topic: trouble with mixtrack pro
can any1 help me iive just got it and and cant get the sound right, in the headphone on each channel, and get it to run through a mixer
geposted Mon 30 Apr 12 @ 9:10 pm
Please see: http://www.virtualdj.com/wiki/MixTrack%20Pro.html
If you are trying to use it with an external DJ mixer and wish to use this for your mixing/headphone pre-listening then you will need to use an external multi-channel DJ sound card such as Numark DJIO.
The sound card built into the MixTrack Pro is not suitable for external DJ mixer use because it only has one stereo master ouput. It's designed for stand-alone all-in-one use only.
geposted Tue 01 May 12 @ 5:36 am
i have it into a mixer to use at home and it only comes out of the headphones not into the mixer told to set up
geposted Tue 01 May 12 @ 6:30 am
Connect a suitable cable (RCA phono) from the master output on the back of the MixTrack Pro to a spare channel on your external mixer.
Plug your headphones directly into the MixTrack Pro.
Then check that your sound is configured correctly as described on the FAQ page above.
NOTE: You will need to use the software mixer section of the MixTrack Pro itself to do your mixing, NOT the external DJ mixer (If you wish to use the external mixer, you will need a suitable sound card such as DJIO, as described above.)
geposted Tue 01 May 12 @ 6:56 am
