Hi Guys I need some help I have not idea what happened my crossfader is not working on my denon mc6000 it used to work, but now I can not make it work. to mix I has to use the volume controllers and manually put crossfader in the middle, very fustrating cause I had this controller over a year and never have any issues.
Also for some reason when I normally start dj, the heapphone start normal, after at least one hour the heaphone sounds distored, really bad.
please help
my system:
windows vista home premium 32bit.
virtualdj 7.5b
Dj Memo
please help
my system:
virtualdj 7.5b
Dj Memo
geposted Thu 10 May 12 @ 9:27 pm
Please check the CF MODE button - This toggles the crossfader between audio, video, both or off.
Also, please see http://www.virtualdj.com/wiki/DN-MC6000.html and also ensure that you have the latest drivers and firmware for the MC6000 installed from http://www.denondj.com
geposted Fri 11 May 12 @ 6:27 am
Thanks for the help. The thing is That it was working fine i haven't done Any update. Even use to Work fine with any skin but not enymore
geposted Wed 16 May 12 @ 7:19 pm
You may have pressed a button by accident.
Also, please be aware that some shifted buttons on the MC6000 have special functions in the firmware (See the MC6000 user manual and firmware update instructions for further details.)
geposted Thu 17 May 12 @ 5:49 am
You probably have inadvertently moved the switch on the back from PC Mix to INT Mix. Put it back to PC Mix and you should be just fine.
DJ James
DJ James
geposted Sat 15 Jun 13 @ 4:06 pm
