Topic: Replay gain support
fmooijPRO InfinityMember since 2004
Hi,
Does virtual DJ read and adapts the gain to the replay gain values set in the MP4 tag (I rip to apple lossless with XLD)?
freek
geposted Wed 13 Jun 12 @ 3:41 am
I looked at beaTunes which claims to edit the iTumes norm (apple standard) tags as well as the replay gain tags.
geposted Tue 19 Jun 12 @ 3:27 am
Now I like to understand if BVirtual DJ will read and use them
geposted Tue 19 Jun 12 @ 3:28 am
Haui70PRO InfinitySenior staffMember since 2008
As far as i know, NO ;-)
Auto Gain – This is the auto gain adjustment setting for VirtualDJ. The values are :
 Disabled – Use the raw db level of the track as it was recorded, ripped, or normalized
 Auto – normalize the track to a 0db level for play
 Auto+Remember – normalize the track to a 0db level for play if loaded for first time, then remember the last db gain adjust for next loading of the track.
 Remember – loads the track the first time using the Disabled setting, then remember the last db gain adjust for next loading of the track
VDJ check the gain, while you do the BPM scan.
Then it act like you can see above!
geposted Tue 19 Jun 12 @ 3:48 am
