Hi All, I just bought DDJ Ergo and I\\\'m unnable to use it. Here is a screenshoot with the compilation of error message and settings. I'm at Win7 (64bits).
I already uninstalled and re-installed everything, nothing works.
Device Manager shows at driver details that they are using windows drivers not Pioneer ones. How Can I proceed?
I have a gig tomorrow and I\\\'m looking forward to use this controller. What can I do?
geposted Thu 21 Jun 12 @ 6:37 pm
I'm also having this problem, did you already managed to fix this?
If so, can you tell me how?
If I take a look at your screen-shot it says that Your audio settings of your computer is configured with the speakers, Shouldn't you select the pioneer for that?
geposted Wed 01 Aug 12 @ 3:52 pm
did you try plug in the unit to a usb, turn on, wait until is completely on and the open the virtual dj?
(portugues: voce tentou ligar a unidade na porta usb, ligar, esperar até que a unidade se ligue por completo e ai sim abrir o virtual dj?)
geposted Thu 02 Aug 12 @ 5:48 am
I can't get it work at all so I've downloaded Serato DJ Intro instead for free...works a treat :-)
geposted Wed 08 Aug 12 @ 4:39 am
From the screenshots i can see that you have an old driver version. Latest available is version 1.1 i believe.
Please visit Pioneer website, and install the latest driver (and firmware if available).
see also here.. for the proper Sound setup .. http://www.virtualdj.com/wiki/DDJ-ERGO.html
geposted Wed 08 Aug 12 @ 6:14 pm
