I read on some other forum that a guy was using dubstep samples or loop tools downloaded from here - VDJ site. Is there such a thing? I can't find it if there is.
Thanks for any replies or advice on another source.
geposted Sat 14 Jul 12 @ 10:09 pm
I use a site called "Looperman" (free site, member supported and created content)..........You might check under download-plugins-samples on the screen you agree seeing now (above).....I wouldn't be surprised if there are not some dub samples/loops uploaded there......Not trying to sound like a smarta$$. I see that you are a "premium pro member" so you are probably already aware of the sample d. loads on the site, but I myself have overlooked more obvious things before...lolol....Hope that helped a bit.....
geposted Sat 14 Jul 12 @ 10:41 pm
I've been buying from this company PLP. Here's a link to 10 free sample/loops
http://www.peaceloveproductions.com/Dubstep_Beats.html
geposted Sun 15 Jul 12 @ 3:02 am
I would also add this one: http://www.lucidsamples.com/54-dubstep-sample-packs
geposted Sat 20 Aug 16 @ 9:54 pm
