I am attempting to record video mixes but it lags. I have done work on the registry for the lag when not recording it works great but not when i record it starts to lag. I NEED HELP ASAP PLEASE
geposted Sat 04 Aug 12 @ 1:20 pm
What video card do you have?
If it's an Intel then it *might* work at really low resolution. More likely is that you would need a decent video card.
geposted Mon 06 Aug 12 @ 8:16 am
Yeah its an intel 1760mb available n e thing ican do..... I already tried to add video mem on registry it stopped the Lag but not when I record vid mix...SUGGESTION?
geposted Thu 09 Aug 12 @ 1:32 am
what codec are you using to record video? you may want to experiment with a few codecs and see what works best with your setup. I use divx codec at a mid to low resolution and get a pretty good result. If I ever get to a point where I want to record in high resolution I will probably use an external device for recording.
You can see some of my results here, http://djsweett.com
geposted Thu 09 Aug 12 @ 10:25 am
http://www.fraps.com/ .............end of story..............
geposted Wed 22 Aug 12 @ 10:42 pm
