Picked up the DJ2Go this evening as a backup but noticed something playing around with it this evening with VDJ 7.0.5.
When playing a song the LEFT jog wheel will stop the song/scratch. When playing a song the RIGHT jog wheel will pitchbend.
How to get them both to perform the same function? The default mapper KEY JOG ACTION JOGWHEEL.
geposted Wed 15 Aug 12 @ 11:21 pm
hmmm nevermind. perhaps the changes confused the system. I closed VDJ and restarted it and now everything is working like it should.
geposted Wed 15 Aug 12 @ 11:28 pm
This was probably because vinyl mode was turned off on one of the decks - Please see our FAQ pages:
http://www.virtualdj.com/wiki/Vinyl%20mode%20is%20turned%20off.html
geposted Thu 16 Aug 12 @ 4:48 am
i've read through the faq wiki and know some basic scripting.
Is there any way to map the jogwheel to function as normal (vinyl_mode) when NOT playing & when playing to act as pitch control (cd_mode)?
The purpose is when I bump it using the crossfader it will not stop the song but pitch bend it slightly. :)
geposted Fri 17 Aug 12 @ 3:26 pm
It will already do that if you turn off vinyl_mode (Go to CONFIG -> Options and change Jog Mode to CD)
You can also adjust the sensitivity of the jogwheel in each mode on the options config screen.
geposted Fri 17 Aug 12 @ 5:03 pm
Yeah I understand that and figured that out but it doesn't quiet perform the way I would like...
When the song is not playing I like it to be in vinyl mode so I can add cue point right at the beginning fast and then while the song is playing have the jog wheel act as pitch_bend/cd mode.
Is that not possible with VDJ Script?
geposted Fri 17 Aug 12 @ 6:15 pm
Map the JOGWHEEL as ..
play ? vinyl_mode off & jogwheel : vinyl_mode on & jogwheel
geposted Fri 17 Aug 12 @ 6:27 pm
DjDAD, PERFECT!!!! I knew it could be done, I just could not figure it out with the scripting. THANK YOU! Am trying this tonight at work, will let you know how it goes. :)
geposted Fri 17 Aug 12 @ 7:32 pm
Okay I don't get it. It is not working this way on the club CPU. I typed in the action exactly. I shut down Vdj and restarted it. Still not working.
What gives?
UPDATE....strangely enough it is now working but without the script. The action is just jog wheel, go figure.
What gives?
geposted Fri 17 Aug 12 @ 10:12 pm
Guys thanks for this - I was gonna ask this same question but with the power of 'Search' I have managed to facilitate my own resolution!!
HAPPY NEW YEAR!!!
HAPPY NEW YEAR!!!
geposted Sat 29 Dec 12 @ 4:05 pm
on my ergo controler, when I try to sync on jog wheel, instead of forwarding, it goes back, is there anything i can do to make it go wright??
please help
please help
geposted Sun 24 Mar 13 @ 8:44 pm
Hi all,
I recently purchased a Numark dj2go mini controller and i'm using Virtual Dj pro.
My question is as followed: My left jog wheel dose not scratch whilst tune is playing but right side is fine. the left jog wheel worked fine, then for some reason not now. Also, the left jog wheel on the screen dose not scratch either(independent of controller).
Can some one help me. :)
many thanks.
Paul.
many thanks.
Paul.
geposted Thu 04 Jun 15 @ 11:33 am
Assuming that you use the default VirtualDj 8 skin, please press the "VINYL" buttons on either side of the jogs so that they are ON (colored, not gray)
geposted Thu 04 Jun 15 @ 2:49 pm
hi
if you hold down the load key on either side (either A or B) under browse on the controller it changes between jog & bitch bend
Hope that helps
Brad
Hope that helps
Brad
geposted Fri 05 Jun 15 @ 2:15 pm
Hello,
when you change in "Options" "Controller" "Deck" from "Automatic(left,right)" to "1,2" or "left,right" it works!
Hope that helps,
Greets, Dude
Hope that helps,
Greets, Dude
tomcatpaul14 wrote :
Hi all,
many thanks.
Paul.
many thanks.
Paul.
geposted Tue 04 Jun 19 @ 6:49 am
@Dudebua, you're replying to a post made Thu 04 Jun 15 [4 years ago] please look at the date in future.
geposted Tue 04 Jun 19 @ 6:54 am
