Yeah I had heard that, but was still uncomfortable with the red spinning light, will do anything I can to keep a night free from incidents. Thanks, I won't actualy have it until tomorrow but I'm psyched for it, got the registry tool ready for scratch latency too;^]
geposted Thu 30 Aug 12 @ 7:12 pm
This tread was made by me, this morning my account can't be accessed.
It's like hacked by someone or there is a problem in DATABASE?
please can someone Help
geposted Sat 01 Sep 12 @ 3:53 pm
How can i do to setting? My new console oj ddj wego is not work with Virtual DJ.
geposted Sun 30 Sep 12 @ 2:07 pm
quais os principais aprimoramentos
geposted Sun 30 Sep 12 @ 4:28 pm
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
geposted Mon 01 Oct 12 @ 9:42 am
Please see http://www.virtualdj.com/wiki/Is%20MIDI%20controller%20NAME%20supported%20by%20VirtualDJ.html
geposted Mon 01 Oct 12 @ 9:44 am
Please I'm need manual for Português...:)
geposted Wed 10 Oct 12 @ 10:21 am
Hi I just bought this cute little toy...but... someone really needs to help me with the settings. The tracks are not playing clean. Little cracks, they keep hanging sometimes... as if virtual dj is overheated or something... I really can't be playing like this on a party...
And it's not the CPU... it just sounds like VDJ can't handle the tracks. Should I set everything for quality then? Of Should I go for latency? I have a strong laptop! Heeelp!!
geposted Sun 09 Dec 12 @ 2:20 am
You may have performance and/or configuration issues with your computer.
Please see: http://www.virtualdj.com/wiki/Performance%20Issues.html
Make sure that you have the latest drivers and firmware installed: http://pioneer.jp/support/download/index-e.html
geposted Sun 09 Dec 12 @ 12:13 pm
In addition to what support said perhaps try a powered usb hub (AC electrical hub - plug unit into hub then hub into CPU) especially if this is happening when mixing videos. The powered hub solved my issue of audio pops when mixing videos.
geposted Sun 09 Dec 12 @ 2:04 pm
i messed with this little controller at GC, although small it does the job at hand well. it does look "toy-ish" and is very small for my tastes but can fill a need when only just enough is needed.
for me the denon mc3000 fills that bill.
imo controllers like software has to be test driven to see what feels just right. i like the mixtrack pro A LOT but the denon mc3000 makes me feel confident due to its build quality.
Id take the traktor s2 if it wasn't for the software.
geposted Sun 09 Dec 12 @ 2:57 pm
Hey anyone know if it is possible to controll the filter with the jog wheels like the wego but with other controllers?
I have a Numark IDJ3 and it doesn have a filter knob, it would be great to control filters with the jog wheel!
geposted Tue 08 Jan 13 @ 1:03 am
please help to make it work with the numark cue pro 7.05, i have the pioneer ddj-wego black, thanks guys and looking forward for your answer..
geposted Sun 20 Jan 13 @ 12:15 pm
I highly doubt that will happen because the Wego is a PIONEER product. Numark and Pioneer are competitors. Your best bet is to upgrade from Cue to Virtual DJ Pro. Another benefit of upgrading to VDJ Pro is you will get updates with the rest of the VDJ community. By sticking with Cue you will have to wait until Numark approves the update.
geposted Sun 20 Jan 13 @ 11:11 pm
You simply have to download and install the latest Cue version from your Download Center.. http://www.virtualdj.com/download/updates.html
geposted Mon 21 Jan 13 @ 8:37 am
the pioneer is the best ??????????
geposted Mon 21 Jan 13 @ 8:46 pm
It depends on your own personal preferences, requirements and budget.
Please see http://www.virtualdj.com/wiki/Which%20is%20the%20best%20MIDI%20controller.html
geposted Tue 22 Jan 13 @ 7:33 am
Olá como fasso para baixar a skin da pioneer ddj wego,alguem ai pode me ajudar
geposted Wed 03 Apr 13 @ 8:03 am
geposted Wed 03 Apr 13 @ 9:25 am
How do i download the software for ddj wego can anyone please send me the link or some tips would be helpful
geposted Wed 12 Jun 13 @ 4:44 am
