Hi,
I bought a controller that had an OEM version - which I have upgraded to the 20 day pro demo and have been playing with settings.
All worked well until now when if I crossfade from B to A it auto-starts deck A.
The same doesn't happen crossfading from A to B.
I've reset mappings to default, checked options, replaced original xml files but it still does it! Happens with previously unused skins too.
This happens if I drag the crossfader using the cursor or use PgDn. Mappings against this are correctly: crossfader -10%
It seems like something is stuck somewhere but I can't find where.
Any help gratefully appreciated as was hoping to try out with the full version at a friend's party...
Many thanks - Adam.
Many thanks - Adam.
geposted Fri 07 Sep 12 @ 11:23 am
Fader start is enabled on the right deck. The skin that you are using may have an option to toggle this on/off.
If not, map a keyboard shortcut to the following to turn it off on both decks:
deck left fader_start off & deck right fader_start off
geposted Fri 07 Sep 12 @ 11:33 am
Thanks - did the trick.
geposted Sat 08 Sep 12 @ 3:29 am
