Hi guys, I have a second laptop that im setting up with vdj pro,but im having problems with activating the video output, in the config settings it is recognising that i have MOBILE INTEL(R)4 SERIES CHIPSET FAMILY and I have video output switched on and hardware accelaration on but getting no video to my external screens, my laptop is a Dell Intel(R) Core(TM)2 Duo CPU P8400 2.26Ghz 3.00GB 32 Bit running on Windows Vista Business, my other laptop works fine in video mode but having trouble with my second laptop.
geposted Wed 19 Sep 12 @ 4:09 pm
Its quite possible that chipset doesn't support accelerated video.
geposted Wed 19 Sep 12 @ 4:14 pm
I Have chipset on my other laptop and it works fine in video mode??
geposted Wed 19 Sep 12 @ 4:30 pm
The exact same chip set? What are the specs of the other machine?
geposted Wed 19 Sep 12 @ 8:17 pm
If it works with the acceleration off and not on then you might need to check if there are any updates to it. It could be solved with maybe a bios update.
geposted Wed 19 Sep 12 @ 8:29 pm
My other laptop has Mobile Intel (R)965 Express Chipset Family
geposted Thu 20 Sep 12 @ 3:00 am
Maybe your resolution is set too high? My VGA-composite adaptor won't work above 1024x768...
geposted Thu 20 Sep 12 @ 4:23 am
Solved the problem, the vga ouput was not activated, sorry guys thanks for the help (-;
geposted Tue 02 Oct 12 @ 3:15 am
