Forum: VirtualDJ Plugins
Topic: [New Effect]Scratch-Slipmode
ChacklPRO InfinityMember since 2007
Hello!
http://www.virtualdj.com/addons/15215/Slipmode_-_Scratch.html
It simulates the Scratching-Slip-Mode of a Pioneer CDJ 900.
The Effect is assigned on master so you will only need to aktive it at one deck and not at all.
For better Timing set off your "Sound-Savemode" in options if you have a good Hardware in your Computer.
Best regards, C.Hackl
geposted Mon 24 Sep 12 @ 12:30 pm
Awesome! I'll try it out tonight
geposted Tue 25 Sep 12 @ 6:19 am
dydy1PRO InfinityMember since 2006
Can someone port that plug-in to Mac too?
geposted Thu 27 Sep 12 @ 10:27 am
i've released the recources - so anyone who is able to convert it is allowed to do it ;)
geposted Thu 27 Sep 12 @ 2:12 pm
I'm having trouble using it.
I try holding down the platter to stop the track but when I let it go it does not continue playing where it would have had I not touched the platter. The platter I hold down is the "Master"
Am I doing something wrong. ?
geposted Tue 02 Oct 12 @ 12:07 am
is it a motor patter or a touchwheel or a speedwheel on your controller?
Does it youm if you scratch at your skin?
Regards
geposted Tue 02 Oct 12 @ 3:30 am
The platters are not Motor but they are touch sensitive. It is a VMS4.1 by American Audio.
If I touch the platter and move it back and forth, it will scratch but when I release it the track does not jump to where it would have been had I not touched it.
It does the same thing when I do this on the skin.
geposted Sat 06 Oct 12 @ 1:01 am
i saw that i got the same Problem at my CDJs when i'm using win7. in win8 it hase worked fine. I'll proove it once this week ;)
Regards
geposted Sat 06 Oct 12 @ 5:49 pm
