hi, i have virtual dj pro 7, and under the drop down menu in the mapping config, there is no selection for simple midi wrapper
i had my apc mapped to virtual dj previously, but i accidently deleted some vdj files in my documents, now its no longer mapped, and i cannot remapp it cause the simple midi wrapper selection is not available.
i am on windows 7 any help appreciated!
geposted Sun 30 Sep 12 @ 10:36 pm
yep Im waiting on an answeer to that myself
geposted Mon 18 Mar 13 @ 10:00 pm
Simple MIDI Wrapper will only appear if an appropriate MIDI device is detected and not already natively supported.
If it was working before then you may have a MIDI conflict on your computer or the device itself may be faulty. Please see http://www.virtualdj.com/wiki/MIDI%20Controller%20Not%20Working.html
You will also need to purchase the full VirtualDJ Professional to use MIDI controllers. All other versions are limited to 10 minutes use at a time as a trial and MIDI will stop functioning after this time until you restart the software.
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
Otherwise, please register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
geposted Tue 19 Mar 13 @ 7:11 am
