Forum: Old versions
Topic: HELP Hercules DJ CONTROL MP3 E2 Scratching problems
Hello,
Just bought a hercules DJ control mp3 E2...i have vdj software 6.04 pro... all the buttons work but i cant seem to get any jog wheel/scratching...even after turning the scratch on and off, reinstalling all the software...please help! cheers
geposted Thu 04 Oct 12 @ 1:32 pm
VirtualDJ v6.0.4 is a very old and out of date version of the software. There have been many changes and improvements to the software since then (See http://www.virtualdj.com/wiki/VirtualDJ_History.html ) - We are now on v7.1 The MP3e2 is natively supported and works perfectly in the latest version.
Please register your serial number on the page http://www.virtualdj.com/users/edit.html and then upgrade to the latest version: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html - VirtualDJ LE for Hercules MP3e2 entitles you to a discount providing that it is not second hand and/or the discount hasn't already been used.
I dont think the jog wheels on that controller are touch sensitive. So you won't be able to really scratch while the song is playing, you can do it while the song is stopped but not really while it's playing. Also you should register your controller and download the new version 7
