I think you should send that directly to support (or cstoll) rather than posting it here, where there's no guarantee they'll see it.
geposted Thu 01 Nov 12 @ 6:27 am
DJTech Mix 101 returned and puchased ION DJ2GO instead.
£20 more but works perfectly with VDJ.
Only thing I don't like is that the nudge wheels are too loose. It's easy to knock them and screw up your playing track. Easily fixed with some bluetac as I don't use them other than for cueing.
geposted Mon 05 Nov 12 @ 4:05 pm
To avoid this, simply turn off vinyl (scratch) mode when you don't need to scratch. You can do this by holding down the LOAD button or via CONFIG -> Options.
It will then pitch bend if you accidentally knock it, which will be far less noticeable, especially if keylock is enabled.
geposted Mon 05 Nov 12 @ 7:45 pm
Excellent. Thanks for that bit of advice. BlueTak gone!
geposted Tue 06 Nov 12 @ 3:37 am
