VirtualDJ 7.2 (10 October 2012)
Update gia Pro Full, Basic, Broadcaster. To neo update einai diathesimo opws panta sto Download Center sas
- new option: colored waveforms (in Config->Options)
- video fade-to-black independent from audio volume (with VDJScript "video_level")
- changed volume faders default curve (quadratic by default, can be changed with VDJScript "levelfader_curve")
- video can be delayed from audio (with VDJScript "video_delay")
- fix cover download from google and from amazon
- fix adding cached netsearch results to cloudLists
- added 9 new controllers
geposted Wed 10 Oct 12 @ 9:41 am
Exei ki allo.....auto emena mou aresei poly..
IMPORTANT NOTE: this version changes the default behavior of the volume faders.
While before the volume fader had a linear curve (meaning you would hear the song even with the volume fader almost at the bottom), they now by default have a quadratic curve (meaning you start to hear the song when the fader is almost at the middle).
The quadratic curve is more in line with the industry standard, but if you got used to work with VirtualDJ's old linear curve, be aware of the change. We recommend practicing a little before going live with the new version.
If you want to get the old behavior back, just use the VDJScript "levelfader_curve 0" or edit the registry "faderCurve" to 0.
geposted Wed 10 Oct 12 @ 9:50 am
Note.
H Home Free version einai akoma stin version 7.05. Epeidi exei ginei allagi ston installer kai panta argei na anevei sto download.cnet, i Home Free version 7.2 tha einai diathesimi se merikes meres
geposted Wed 10 Oct 12 @ 10:35 am
re pedia pos ginete na exo egatestimeni tin 7.0.4 na kano check for update kai na mou lei oti exo egatestimeni idi tin teleftea anavathmisi????
geposted Wed 10 Oct 12 @ 11:55 am
Endexomenws na min leitourgei sosta to update mesa apo to programma kathos poloi paragontes paizoun rolo, alla den blepo logo na to kaneis etsi.
Panta pigaineis sto download center gia ti teleytaio update :
http://www.virtualdj.com/download/updates.html
geposted Wed 10 Oct 12 @ 12:08 pm
etsi ginontai pio oraies koftes allages e? i emena mou fanike?
geposted Wed 10 Oct 12 @ 12:44 pm
Δεν σου φάνηκε... Να το πω απλά στα ελληνικά:
Τώρα τα ποτενσιόμετρα του VirtualDj λειτουργούν εκθετικά (ακολουθώντας εκθετική συνάρτηση) αντί για γραμμικά.
geposted Wed 10 Oct 12 @ 1:11 pm
Kyrioi... ekana megali prospatheia gia na to exoume auto.
Htan kati pou to virtualdj meionektouse kai gia kapoio logo poloi ligoi eixan asxolithei mazi tou.
Oi linear kampiles pou eixe to virtualdj gia ta volumes ws tora einai kales gia kapoia hdi mousikis kai gia begginers alla to standard stous miktes einai pleon logarithmika faders.
Enjoy !
ps. proorizotan gia tin version 8 - kalws pou to exoume apo twra stin dokimasmeni v7.
Enjoy !
geposted Wed 10 Oct 12 @ 1:30 pm
Enjoy !
Enjoy !
Εισαι φοβερος! Το ειχαμε συζητησει στο chat και μου ελεγες οτι δινεις αγωνα γιαυτο και μεσα σε 2 εβδομαδες βγαινει update και το εχει!
Πραγματικα παρα πολυ χρησιμο για οσους χρησιμοποιουν το controller σαν μεικτη! Και παλι μπραβο στην ομαδα που μας εκπλησει θετικα για μια ακομη φορα!
geposted Wed 10 Oct 12 @ 3:48 pm
Ερώτηση? τις πάνω κυματομορφίες πως μπορούμε να τις έχουμε και αυτές έγχρωμες?
geposted Thu 11 Oct 12 @ 1:53 am
Το Rythmview δεν γίνεται έγχρωμο, και δεν έχει και νόημα (δεν θα ξεχωρίζουν η μία από την άλλη).
Δεν ξέρω τι θα γίνει στην 8, αλλά για το rythmview θα είχε περισσότερο νόημα απλά να αλλάζει η ένταση του χρώματος, αντί για full color.
geposted Thu 11 Oct 12 @ 2:01 am
ακομα και οι αλλαγες με beatmatch μου ακουγονται καλυτερα :)
μπραβο!
πληροφοριακα, και οι μικτες ετσι δουλευουν?
geposted Thu 11 Oct 12 @ 7:51 am
εμενα θα μ΄αρεσε γιατι τα χρησιμοποιω ξεχωριστα οπως ειναι στο traktor και με βολευει καλυτερα...
επισης θα ηθελα να μπορω να διαλεξω εγω το χρωμα του waveform και οχι αναγκαστηκα σε κιτρινο που ειναι τωρα.
η τουλαχιστον να ειχε διαφορες ετοιμες επιλογες για χρωματα. κατι σε μπλε θα ηθελα οπως το traktor.
τωρα οπως ειναι σε κιτρινο, στο δεξι deck, πολλες φορες, γινεται κοκκινο λογο εντασης κτλ και δε μπορω να ξεχωρισω
που βρισκεται το τραγουδι εκεινη τη στιγμη.
geposted Thu 11 Oct 12 @ 7:56 am
για παραδειγμα, δειτε εδω, που βρισκεται το τραγουδι οεο??
παρολο που το εχω κανει μεγαλο στο δικο μου skin, αντε να το ξεχωρισεις με μια γρηγορη ματια.....
geposted Thu 11 Oct 12 @ 9:03 am
kalispera aledjo . to skin afto pou vlepo pou mporume na to vroume ?
geposted Thu 11 Oct 12 @ 4:53 pm
Δε το εχω τελειωσει ακομα. βασικα περιμενω να βαλουν τα covers να φαινονται στα decks.
οποτε υποθετω οταν βγει το 8 θα τελειωσω μαζι με extra λειτουργιες που εχω σκεφτει......
geposted Thu 11 Oct 12 @ 5:44 pm
paidia to neo scratchwave einai poly bari.... otan to energopoio sto laptop, sernetai.....
geposted Fri 12 Oct 12 @ 5:43 am
ennoeis tis colored waveforms ? den blepo diafora sto pc mou, alla mporeis na tis apenergopoieis na ksekourazontai kai ta matakia..
geposted Fri 12 Oct 12 @ 8:13 am
se emena kateybazontas toys teleyteoys drives tis kartas grafikwn (NVIDIA) estrose
geposted Fri 12 Oct 12 @ 8:25 am
Εμένα, οι τελευταίοι drivers της NVIDIA ήταν όλεθρος για το Virtual και γενικά για το σύστημά μου.
Μόλις ενεργοποιούσα το Video από το Virtual έβλεπα στην οθόνη της τηλεόρασης (composite σύνδεση), την εικόνα μου Cropped!
Και πολύ Cropped μάλιστα.
Δηλαδή, χανόντουσαν οι δεξιοί και αριστεροί χορευτές και εμφανιζόταν μόνο ο τραγουδιστής που τυχαία ήταν στο κέντρο.
Αν από λάθος απενεργοποιούσα τη λειτουργία video... η NVIDIA διέκοπτε τα πάντα προς την τηλεόραση και η τηλεόραση μου έδειχνε "No signal".
Με τους παλιούς Drivers, έβλεπα την επιφάνεια εργασίας όταν αντίστοιχα έκλεινα το Virtual.
'Οτι κι αν δοκίμασα δεν έστρωνε. H Nvidia είχε γκαγκανιάσει τόσο πολύ που η τηλεόραση έδειχνε ΣΥΝΕΧΕΙΑ το "no signal".
Μέχρι που έκανα επανεκίννηση αλλά και πάλι συνέχιζε η εικόνα να είναι κομμένη.
ΤΕΛΙΚΑ ΕΠΕΣΤΡΕΨΑ στου drivers 285.62, αφού οι τελευταίοι 306.97 δείχνει ότι κάνουν πολλές βλακείες!
geposted Sat 13 Oct 12 @ 8:51 am
