Loop the track in whichever way you like..... and the track returns to where it would have been
Would be great if VDJ could do this
geposted Wed 10 Oct 12 @ 10:34 am
          That seems like the Pioneer Slip Mode. Already asked several times.
    geposted Wed 10 Oct 12 @ 10:37 am
          chackl just released a plugin for slipmode that works great.... if you want the hot cues you can map
goto_cue 1 while_pressed
geposted Thu 11 Oct 12 @ 4:06 am
Thanks for the tip synthet1c.
Any idea how to keep a loop set after release?
I set a 4 bar loop and then used my goto_cue1 while_pressed button and it went to cue1 and it started a 4bar loop. On release it went back to the previous spot in the track and continued, but it exited the loop.
I'd actually like it to go to cue and play while_pressed without loop and then upon release go back to previous spot and continue loop where it left off.
geposted Wed 29 May 13 @ 3:39 pm
          It's a bit of an ugly workaround but
goto_cue 3 while_pressed & down ? loop 100% : loop 100%
geposted Wed 29 May 13 @ 4:57 pm
Thank you for that.
Is there a document that has the command variables? I already set some custom settings, but would love to have a list of all useable commands ie: goto_cue 1 set pitch -3%
pitch, loop, while_pressed, down, led on or off
    Thank you for that.
geposted Wed 12 Jun 13 @ 3:35 pm
          yep that is why the wiki exists ☺
http://www.virtualdj.com/wiki/VDJscript_verbs.html
http://www.virtualdj.com/wiki/VDJscript.html
geposted Wed 12 Jun 13 @ 3:48 pm
          Hi to all,
Is there any news about this function?
geposted Sun 01 Apr 18 @ 8:54 am
          Please take the time to read the manual...
https://www.virtualdj.com/manuals/virtualdj8/interface/decks/decksadvanced/loops/index.html
Also please do not bump five year old threads.
geposted Sun 01 Apr 18 @ 9:04 am
