i was wondering about having the ability of locking some of the faders so that they only do a portion of the effect faders as some of the effect faders totally go past the use it point.. its just wasted noize
geposted Fri 12 Oct 12 @ 2:25 am
param_multiply 25%
param_multiply 50%
param_multiply 75%
etc...
Those will restrict the amount of the effect your knob/slider will controll...
param_multiply 50%
param_multiply 75%
etc...
geposted Fri 12 Oct 12 @ 2:56 am
most awesome.....Thanks I cant wait to program it..
geposted Mon 15 Oct 12 @ 12:00 am
I should mention that you can also use param_add and param_invert
eg if you want to have the knob only control 75% of the total effect slider but want it to start from 25% you would use
param_multiply 75% & param_add 25% & effect 'effect_name' slider #
you could also use param invert to swap the way the knob turns. It comes in handy when you want to have a dual effect knob split in the middle, kind of like a hp/lp filter knob but with any effect your heart desires.
geposted Mon 15 Oct 12 @ 12:23 am
is it posible to make each effect when pressed have the effect slider work in this mannor for each?
geposted Mon 22 Oct 12 @ 3:33 pm
