Hello!
I just wanted you to share my new update with version 3.
NO VST ANYMORE!!!
If someone of the Moderator could please be so kind to change the Effektname to "RollIt" because VST is now wrong.
The effeckt is now based on the SDK V6 and complet rewritten. After a bugfix-feedback i'll add the version for mac Users.
Rollit simulates an advaced Roll of a Pioneer CDJ 400. Some know the effect from the beginning of "Swedish House Mafia - One"
http://www.virtualdj.com/addons/13517/_VSTi__RollIt_.html
Regards, C.Hackl
NO VST ANYMORE!!!
Regards, C.Hackl
geposted Wed 17 Oct 12 @ 1:25 am
Update 3.1:
added the quantised Loop Length like in Version 2
Released MAC User Version
Regards, and much fun with it,
C.Hackl
C.Hackl
geposted Wed 17 Oct 12 @ 11:04 am
Chackl wrote :
Update 3.1:
C.Hackl
C.Hackl
Very nice! thank you for the Mac version. I will try It and let you know.
geposted Thu 18 Oct 12 @ 7:28 am
What are the default settings for the effect RollIt again please?
geposted Thu 18 Oct 12 @ 9:42 am
Default is:
Mix Slider 50%
Speed Slider 50% - Original Speed
Length Slider is 50% - Loop half beat
Quant is off
sync on CBG is off
Extended Rage is off
Regards
Mix Slider 50%
Quant is off
sync on CBG is off
Regards
geposted Thu 18 Oct 12 @ 10:56 am
Chackl wrote :
Default is:
Mix Slider 50%
Quant is off
sync on CBG is off
Regards
Mix Slider 50%
Quant is off
sync on CBG is off
Regards
Thank you very much.
geposted Thu 18 Oct 12 @ 2:43 pm
is there a way to map the effect so that when you activate it, the speed slider automatically changes to 50% (original speed) ?
geposted Sun 30 Dec 12 @ 2:17 pm
try this:
regards
effect 'rollit' active & effekt 'rollit' silder 2 50%
regards
geposted Wed 09 Jan 13 @ 7:03 am
tried it...doesnt seen to be working man
geposted Sat 12 Jan 13 @ 2:37 pm
there is a simple spelling mistake
effect 'rollit' active & effect 'rollit' silder 2 50%
geposted Sat 12 Jan 13 @ 3:45 pm
oops ^^
it happens to often to me :P - sorry for the mistake
geposted Mon 14 Jan 13 @ 6:03 am
fixed the spelling and still no luck haha
geposted Mon 14 Jan 13 @ 7:59 am
ok there were 2 mistakes :P
how about now?
effect 'rollit' active & effect 'rollit' slider 2 50%
how about now?
geposted Mon 14 Jan 13 @ 8:22 am
ok so i opened mappers and then copied and pasted: effect 'rollit' active into "key", and effect 'rollit' slider 2 50% into "action"...pressed enter, and still nothing man lol im prob doing something wrong
geposted Tue 15 Jan 13 @ 3:34 pm
ämm no ....
Just seach the key you want to map this action in the list at mappers.
Then copy and paste the action to action - Just leave KEY as it is after you selected your button.
at action you have to paste the code i gave you that post above ;) - the whole code - not just a part - you have to copy the whole code there ;-)
geposted Wed 16 Jan 13 @ 6:23 am
thank so much man it worked
geposted Mon 21 Jan 13 @ 7:15 pm
