Hello!
I just wanted to ask / request a set_deck funktion.
This means for example is you press a button that is on deck 1 and you set "set_deck 1" the whole controller's deck 1 is turned into deck 3.
also interresting to include:
set_deck +1 ... set the next deck (e.g. Deck 2 to Deck 3)
set_deck 'leftdeck' ... sets the deck to Leftdeck
set_deck 'masterdeck' ... sets it to masterdeck
set_deck 'selected' ... set deck to selected deck
set_deck 'device' ... sets the deck to the device default
Thiswould be verry gerat because if you have 4 CDJs that display the decknumber you could juse with holding the Next/Prev Loop-CUE Buttons to select the deck that it should be verry fast and efficient.
Regards,
C.Hackl
Regards,
C.Hackl
geposted Thu 18 Oct 12 @ 9:05 am
You can almost do the same stuff with assign_controller command.
geposted Thu 18 Oct 12 @ 9:58 am
