bonjour a tous ,j'ai voulu installer des effets dans sur vdj,mais en fait quand j'ai été dans la rubrique des effets a telecharger,j'ai remarquer que la descriptions de ceux xi était en anglais existe til pas une descriptions des effets en français pour au moins savoir ce que l'on instal?merci
geposted Mon 22 Oct 12 @ 4:18 am
Utilise Reverso : Google
Donne nous le nom ou fais un copier/collé sur ton post du descriptif de l'effet.
geposted Mon 22 Oct 12 @ 4:34 am
Description:
Essential MEDIA plug-in for Virtual DJ - version 2.08a
Take your VirtualDJ software experience to the next level with Essential MEDIA!
This plug-in is essentially a media player, which allows you to instantly select and play many types of media files, including Adobe FLASH files and even CDG Karaoke files within the Virtual DJ environment. A video camera input is also provided, with lots of flexibility. Best of all, the output quality is the smoothest available!
Check out these blockbuster features and benefits:
* Playback of Video, SWF, CDG, FLV, F4V, RM, WMV, AVI, ASF, MOV, MP4, M4V, MKV, VOB, TS, OGV, 3GP, and DIVX
* Allows you to quickly select up to 48 clips divided over 4 banks
* Allows quick loading and saving of clips, even while using VirtualDJ
* Use VDJscript to control Essential Media from your external controller
* Playback modes include Automatic, Random, and Manual
* Allows you to control the size and placement of Video or Camera
* Support for crossfade, stretch and aspect scaling
* Embed live camera feed right into VirtualDJ with high resolution
* Alpha channel support for any video format that supports it
Note that this plugin provides the only NATIVE (i.e. direct) way of playing Adobe FLASH files in Virtual DJ.
For more information about this, go to http://www.PangolinPlugins.com
(Note that Essential MEDIA is a
geposted Mon 22 Oct 12 @ 5:44 am
voute2 wrote :
Description:
Description :plug-in MÉDIA indispensable pour Virtual DJ - version 2.08a
Amenez votre logiciel VirtualDJ expérimenté vers un niveau supérieur avec média essential !
Ce plug-in est essentiellement un media player, qui permet de sélectionner instantanément et de jouer de nombreux types de fichiers multimédias, notamment des fichiers Adobe FLASH ainsi que les fichiers dans l'environnement virtual DJ karaoké CDG.
Une entrée vidéo caméra est également fournie, avec beaucoup de souplesse. Le meilleur de tout, la qualité de sortie est la plus lisse possible !
Découvrez ces fonctionnalités blockbuster et avantages :
Lecture de vidéo SWF, CDG, FLV, F4V, RM, WMV, AVI, ASF, MOV, MP4, M4V, MKV, VOB, TS, OGV, 3GP et DIVX
Permet de sélectionner rapidement jusqu'à 48 clips réparties sur 4 banques
Permet rapidement de charger et enregistrer des clips, même pendant l'utilisation de VirtualDJ
Utilise VDJscript pour contrôler le média essentiel de votre contrôleur externe
Les modes de lecture inclus sont automatique, aléatoire et manuel
Permet de contrôler la taille et le positionnement de l'appareil photo ou vidéo
Support (aide) pour le fondu enchaîné, étirement et aspect mise à l'échelle
Incorpore le live video VirtualDJ avec haute résolution
Support alpha channel pour n'importe quel format vidéo pris en compte
Notez que ce plugin fournit la seule façon NATIVE (c'est à dire directe) de lire des fichiers Adobe FLASH dans Virtual DJ.
Pour plus d'informations à ce sujet, allez sur http://www.PangolinPlugins.com
(Notez que média essential est un
juan
geposted Mon 22 Oct 12 @ 7:01 am
Merci,pour cette traduction, mais la je rceherche un plug pour crée une image de presentation pour les mix video, une sorte de générique de début et de fin
geposted Tue 23 Oct 12 @ 5:14 am
