Ok so I think most people record in that format. Recently I recorded a mix in WAV. Because when I tried in mp3 it said codec error or something of that sort. Any difference between the two? Like stated it worked just fine in WAV but I thought I would have all options so why would it not work in mp3?
Thanks
Thanks
geposted Mon 29 Oct 12 @ 12:35 am
Wave files are uncompressed raw audio where MP3 files are compressed and smaller.
Wave files sound better but take up far more disk space. You can only have a max file size of 4gb on a wave file due to the 32bit header.
Keith
Keith
geposted Mon 29 Oct 12 @ 3:29 am
Please see http://www.virtualdj.com/wiki/MP3%20Encoder%20Error.html
This should allow you to fix the error and record directly in MP3 format.
geposted Mon 29 Oct 12 @ 10:19 am
I will just continue with WAV files. I don't make long mixes so I will stick with quality.
Thanks for clarifying
geposted Mon 29 Oct 12 @ 5:58 pm
