I am presently using turntables and my hercules 4mx as the mixer using Vdj pro. i will now like to incorporate my hercules mp3 e2 with this setup. i actually just want to use it as like an imaschine ( just more for the effects aspect). The drivers somehow seem to overwrite each other, anytime i try to install either. Could this be done? Cause i have tried a couple other stuff but was not successful.
geposted Mon 29 Oct 12 @ 3:19 pm
i had the rmx and the mk4 working together.. the main set up is in the sound config.. the issue becomes that one will do the top set of decks and the other for the other 2. It can be mapped to do different things..
geposted Tue 30 Oct 12 @ 11:45 pm
You need to connect BOTH devices when installing the drivers. This way both devices will be installed properly.
geposted Thu 01 Nov 12 @ 3:24 am
I got it going... the issue was that i needed to update the Mp3e2 files and from the 'task Manager'.
Thanks for the help!!
geposted Thu 01 Nov 12 @ 6:44 pm
