Hi,
I'm attempting a 4 deck setup. Here's my hardware:
VirtualDJ v7.2.
Windows 7 x64 (specs here: http://www.samsung.com/us/computer/laptops/NP700Z3A-S01US-specs) with latest drivers.
Hercules Deejay Trim 4&6 with latest drivers.
2 x Pioneer CDJ-400 controllers (latest firmware and drivers).
1 x Pioneer DJM-700 mixer.
Here's my (Advanced) sound configuration in Virtual DJ:
Deck 1 - Pioneer-CDJ400 (1) - Output 1&2
Deck 2 - Pioneer-CDJ400 (2) - Output 1&2
Deck 3 - Hercules Deejay Trim 4&6 - Output 1&2
Deck 4 - Hercules Deejay Trim 4&6 - Output 3&4
All the output channels are mapped correctly, and all the controls and sound outputs work.
The problem is that the sound is very choppy on all channels, with regular pops and clicks. It's especially noticeable on Deck 1 and Deck 2 (The Pioneer sound outputs).
I have run the DPC Latency Checker and there are no reported problems. Everything is green.
Can anyone suggest what the problem is here?
Has anyone ever successfully run a 4 deck setup on Virtual DJ? What was your configuration?
Thanks.
VirtualDJ v7.2.
Thanks.
geposted Thu 01 Nov 12 @ 2:53 pm
I ran into the same problem when I tried using 2 different soundcards. I can't give you a detailed explanation but I think you'd be better off using an Audio 10 or anther soundcard like that.
geposted Thu 01 Nov 12 @ 4:04 pm
